| Chip Amps Amplifiers based on integrated circuits |
Hi guys, I just finished builing my gainclone on a PCB i designed in Protel.
I tested the amp before connecting it to a heatsink for DC offset and it was at ~20mV for both amps. Then I connected it to a speaker and this is when I noticed a hum sound which increased to a higher pitched sound over about 5 seconds. I figured I could test out the amp at low volumes before I attached it to a heatsink (which I am yet to purchase). Can you check this amp at all without some kind of heatsinking or is it not going to work? Could this cause this weird sound I am hearing or is it my PCB design (which is attached)? Any help would be great thanks -Mikey |
#2 |
Mikey,
Which chip did you use? LM3886? Do you have a link to the schematic? /Hugo |
#3 |
I used the LM3875
The schematic is attached. -Mikey |
#4 |
A note, don't mind the three resistors and their values. I put it like that cause I figured I could match up to three resistors to get a niec precise value. I am using just one 220K 1% resistor in place of the three.
The signal and power grounds are connected -mikey |
#5 |
I see the +in could use a resistor before hitting ground.
http://gainclone.com/inv_gainclone_1.gif /Hugo |
#6 |
I would advise to not use that chip without heatsink! It can easily damage that way, even considering the internal protection. Just use a metal bar or an old pentium cooler with a hole drilled in for testing.
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits... |
#7 | |
#8 | |
Your amplifiers may oscillate. In an inverted setup, it is very important that the source (with a small output resistance) is connected to prevent oscillation. Regards, Milan |
#9 | |
I'm ready to prove everything I have said, for I can find good witnesses. |
#10 |
http://www.decdun.fsnet.co.uk/gainclonecircuits.html
That's the schematic my amp is based on. Maybe the minimised approach is suitable for point-to-point wiring only? I will try tying the non-inverting input to gruond with a resistor and attach a source. I will go buy some heatsinks too, which I will need anyway and try this PCB and amp out again. Thanks for the help once again guys. -Mikey |
| New problems with old Gainclone... | sek | Chip Amps | 13 | 4th February 2008 12:48 AM |
| Problems designing an PSU for an gainclone. | samsagaz | Chip Amps | 23 | 30th August 2007 03:20 AM |
| problems wiring Brians gainclone kit | Jimmy D. | Chip Amps | 9 | 12th December 2004 02:47 AM |
| Gainclone with DC-offset problems | seve | Chip Amps | 11 | 29th May 2004 12:01 AM |
| Gainclone Problems; Aahh! | raffir | Chip Amps | 12 | 22nd April 2003 10:56 PM |
| Page generated in 0.10778 seconds (76.62% PHP - 23.38% MySQL) with 11 queries |
