| Chip Amps Amplifiers based on integrated circuits |
#11 | |
As I can configure that board in all 3 modes of operation (using basically same components), my preference with regards to the sound is as follows: 1 bridged 2 stereo 3 parallel
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#12 |
So I want to know if it is dangerous to have 6 ohm speaker on a LM4780 in bridge mode?
#13 |
This may help you.
www.national.com/an/AN/AN-1192.pdf#page=1 Read page 3. Dont forget lm4780 is 2 lm3886 in one case so pd might be alittle less. |
#14 | |
The 4780 cannot safely drive a 3 ohm load, and that is what the effective load will be for the amp on each half of the bridged amp. 6 ohm is a awkward impedance to use... bridging results in a 3 ohm effective load which is too lown to be safe, and paralleling results in a 12 ohm load which is too high (it's perfectly safe, but you will not get as much power out of the chips as you would with 8 ohms, because of the limits on power supply voltages). The ideal solution for 6 ohm speaker is a bridge-parallel amp. This is contructed as two parallel amps, bridged together. The "parallel amp" parts of this can have as many chips in parallel as you want; you are not limitted to two. If you use 4 chips total (2 in parallel each side) then the effective load to each chip is 6 ohms. You can calculate the approximate output power by figuring out (with the help of the datasheet and/or the Overture Design Guide spreadsheet from National) the output power of the chip into 6 ohms (effective load per chip) and multiplying that by 4 (total number of chips). If you used a three chips in parallel on each side (6 total), then the effective load per chip is (6*3/2) = 9 ohms. To calculate the approximate power of this, find the output power for each chip into 8 ohms and subtract 11% (due to the load being 9 ohms), and multiply by 6 (total number of chips). For more information on bridge-parallel amps, download National's app note AN-1192 and their Overture Design Guide spreadsheet |
| The difference of Push-pull,Half-bridge,Full-bridge | digi01 | Chip Amps | 0 | 8th September 2006 03:10 AM |
| PCM1792 in parallel mode | babaudio | Digital Source | 0 | 12th July 2005 11:26 AM |
| Difference bewteen ultralinear & triode mode? | kevinkuang | Tubes / Valves | 10 | 13th April 2005 10:11 AM |
| Whats the difference between full bridge and half-bridge SMPS ? | skaara | Class D | 6 | 3rd February 2005 08:23 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Page generated in 0.08594 seconds (79.88% PHP - 20.12% MySQL) with 10 queries |
