Old 10th July 2005, 01:16 PM   #21
"Technically, 24V should be ok"
Are you sure? The maximum supply voltage for the LM4700 is 66v; and when you switch the power on, the transformer output voltage will be some volts higher than its nominal rating. You'll lose about one-and-a-half volts through the rectifiers; but even so I'd have thought a 24v transformer with 5% regulation could generate at power-on a DC split voltage of 70 volts ... more if your mains power goes higher than its nominal value. (Perhaps someone with more experience of power supplies could comment.)
Anyway, you'd be better off with a transformer with 20v secondaries. That will give a split rail power supply of about +- 28 volts, which gives you a comfortable safety margin.
Are you using the same power supply capacitors for all the amplifiers? If not, you can have a regulated power supply for each amplifier chip, so each chip has its own supply voltage. But that's more expensive and complicated than simply using the same amp chip for each channel.
"I want to do (2) LM3886, (1) LM3875, and (1) LM4700 from one transformer ..."
It does seems complicated to use several different amplifier chips. Is there some advantage compared with using, say, 4 LM3875s? It's not as if the chips cost much.
Tim
Tim Martin
Old 10th July 2005, 02:42 PM   #22
You could get the 25 volt Avel transformers and use 2 x LM338 with a 5 volt drop and this will give you about 30 Volts DC output,
this wil be a happy value for all of your chips.
use Carlos' suggestions for component values.
Sheldon D
Old 10th July 2005, 03:27 PM   #23
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
I have 68000uF caps, was going to put one of those per rail (so 2 per transformer) between the PSU and amps, and then put maybe a smaller el and a film cap in parallel at each amp
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.09515 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
