buffer noise
buffer noise
Old 30th June 2005, 03:29 AM   #1
Sheldon is offline Sheldon  United States
Default buffer noise
The info I seek may be buried here somewhere, but I couldn't find it. The problem is a slight amount of hum. By slight, I mean about 3mv ac on the output of the amp (both inverted and non-inverted). I didn't care much before as the speakers I were using were not real efficient and the hum was low enough to be inaudible until very close. I now have an application with more efficient speakers and would like to minimize hum.
The chip-amp part, built on Brian GT's original boards doesn't seem to be the problem. Both amps have discreet jfet buffers, ala Pedja. If I short the buffer output to the amp, I get a fraction of a milliamp hum at the ampt output. No change (that is, the same 3ma or so)if I short the input to the buffer. So, the slight hum I get is from the buffer itself. Any obvious layout issues anyone is aware of, that I should check before I dig in and start probing around? One buffer is powered by three-terminal regulators on the board the other set is powered by a discreet ps separate from the buffer board. Both amps use Pedja's discreet regulator supply as the main supply.
Sheldon
Old 30th June 2005, 03:44 AM   #2
On Hiatus
SY's Avatar
buffer noise
Is it 50/60Hz or 100/120Hz? Different causes. Yes, 3mV is much too high.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th June 2005, 05:22 AM   #3
Sounds like 120 to me. Inadequate ps filtering?
Sheldon
Old 30th June 2005, 05:27 AM   #4
On Hiatus
SY's Avatar
buffer noise
It could be (I don't know what the power supply rejection is like for that circuit), but more likely, it's a grounding issue. Power supply ripple is being impressed on the signal.
Old 30th June 2005, 02:39 PM   #5
You're probably right on that score. I think the psrr is fairly good. And in any event, there ain't much ripple. If I use my multimeter and put a 0.1uf cap in series with the probe, I measure about 3mv. Plus that supply on the one amp then supplies 7815/7915 for the buffer, I measure about 1mv there. I put caps after the regulators (about 10uf, I think) and I wonder if that might be a source of the ground noise. I'll play today. I can test with 9v batteries too.
It's a bit mysterious, as I have the grounds lifted from the mains ground with a 25ohm resistor, but maybe I've made some other error. Time to dig in.
Sheldon
Old 4th July 2005, 09:04 PM   #6
Well, I dug in. Checked out everything I could think of. The grounding scheme seemed fine. One last test. I disconnected the power supply and powered it up from another clone power supply. Noise went from 3mv to 0.2mv.
Conclusion? I've just got too much stuff in too little space and I'm getting inductive coupling somewhere. Probably doesn't help the case is aluminum (one of Peter's nice cabinets). It's the buffers that seem to pick up the noise. In the second amp (the one I used for power) I get about 0.6ma noise, but the buffers in that one are further away from any ac source. Looks like the solution will be to make a separate case for the power supply.
sheldon
Old 5th July 2005, 06:11 AM   #7
fallow is offline fallow  Finland
Could you put shematic and layout pictures here?
It would be much easier to track the problem with the grounding.
Old 5th July 2005, 06:42 AM   #8
asgorath is offline asgorath  United States
If you're picking up mains signals couldn't you just shield the entire input buffer with some copper foil? Or if you want another way build the entire input inside an altoids tin.
Tell us how it works out. I'm planning on using the JFET buffer myself.
Old 5th July 2005, 08:21 AM   #9
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Sheldon, following this thread, and reading Pedja's pages again led me to the thread where I think it was you who first put forward the idea of shunting the output of the buffers to ground while they warmed up.
So this is just to say thank you for that idea which works well. I have written up all the details here .
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th July 2005, 05:24 PM   #10
Instead of that fancy 555/relay circuit how about a simple capacitor charging circuit to hold on the mute feature of the chip until everything is warm? I mean, as far as I know all this bad noise during power up won't hurt anything, it just sounds bad.
Please correct me if I'm wrong.
buffer noiseHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
B1 buffer pmchoong Pass Labs 1 11th May 2009 05:48 AM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
