| Chip Amps Amplifiers based on integrated circuits |
Hello !
Can anybody comment if the schematic for connecting the OPA549 on the single supply is correct ? If it is not please give me some advice how to make it right. Cheers
Some are born with more and some born with less so don't take for granted the life we've been blessed it's hard to understand thet we're only a guest and each one of us shall be put to life's test. |
#2 |
There's a few errors, look at your power supply connections. But more importantly why would you want to run with a single rail? You now have to use a coupling cap at both the input and output which isn't what I'd recommend for anything related to hifi. If you only have a 30-volts single rail you can also split it to 2x15 and settle on that.
Best regards, Sander Sassen http://www.hardwareanalysis.com |
#3 |
I have to put this amp in an guitar amp where I have only +30V DC. Can you tell me where are the errors at the power suply connection ?
Cheers
#4 |
When do you not have a negative supply. The V- conector go to GROUND.
Brazilian Tube Amp Builder. |
#5 |
Banned
Hi bostjancek,
Yes, there are a few errors on your shematic. The 4,700uf + 100nf caps are in series with the positive voltage rail (?!), they should be parallel from V+ to ground. The input 2.2uf cap should be before the 47k cap. And a suggestion: use a 4,700uf cap on the output, although not so important for a guitar amp. |
#6 | |
And... use a snuberized PSU ... I like the snubber that sound is more beautiful than the others schematics! I love your idea.Thanks
#7 | |
Banned
#8 | |
One suggestion: Try a different way for your virtual ground input connection. Increase the value of those resistors to something like 47K each, and don't connect that point directly to the + input, but through another 47K resistor. Then use a a 1uF capacitor from that middle resistor point to the V- rail. That should lower your ripple noise. Or use the parts used in the LM3886 datasheet for single supply application. A single supply design has several flaws, the large output capacitor being the main one. So I don't think it will help much using a snubberized supply with it. Carlos |
#9 |
Thanks for your comments. I realy don't know where my head was when I drown the given schematic.
Cheers !
| Single Supply Amp help - LM3886? | GePeW | Chip Amps | 104 | 22nd November 2007 10:38 PM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
| OPA549 supply questions | sobazz | Chip Amps | 16 | 12th July 2005 12:57 PM |
| single supply opa549 | soundNERD | Chip Amps | 12 | 21st April 2005 09:03 PM |
| LM3886 single supply. | unitgain | Chip Amps | 2 | 24th March 2004 12:10 PM |
| Page generated in 0.11853 seconds (63.96% PHP - 36.04% MySQL) with 11 queries |
