| Chip Amps Amplifiers based on integrated circuits |
I´m amazed!
hi ya,
i have my ultra-compact high-cap snubberized t-network inverted gainclone (phew !) in progress. the whole thing measures 105 x 105 x 165 mm (~4,1 x 4,1 x 6,5 "). one decision is left to make:the halfs of the alumimum box shown are to be put together open side to open side and fixed with screws on front and back panel. what would you prefer: trafo just above the chip and shielding both trafo and chip with and / or copper sheet and the magnetic stuff on the right (salvaged from a dead computer monitor)? wiring from rectifiers to psu would be 60 mm (~2,4"). or should i turn the right half so that the trafo is above the capacitors and the cabling from rectifiers to psu is 220 mm (~8,7") ? i´m not shure if there is any drawback in the quite long cabling, but otherwise i think the inductivity shouldn´t affect as it would be before the caps. i dislike the idea of having the trafo directly above the chip ... [B]
#2 |
I built a similar amp into the same chassis and had the same issue, i solved it by putting a 6mm thick peice of copper plate inside the housng to divide it into two boxes. This worked pefectly and even though my lm3886 is only maybe 4-6cm above the tranny i have no humm what so ever.
![]() fil |
| Trafo question... | Dxvideo | Chip Amps | 7 | 26th September 2007 06:33 PM |
| Positioning question | Dxvideo | Solid State | 4 | 1st May 2007 06:18 PM |
| 230v trafo question | giantstairs | Chip Amps | 7 | 5th March 2007 02:01 PM |
| PS question- Need to get 20V AC from 60V AC - w/o Trafo | lgreen | Pass Labs | 9 | 2nd January 2004 10:31 AM |
| Question about transformer positioning. | G | Tubes / Valves | 30 | 6th January 2003 09:28 PM |
| Page generated in 0.06657 seconds (69.58% PHP - 30.42% MySQL) with 11 queries |
