Old 16th June 2005, 04:55 PM   #1
Send a message via ICQ to eranrund
Default My first non-inverted gainclone circuit
Hello people.
Below is my first non-inverted gainclone circuit. It is powered from a toroid-based power supply which will supply around 25-30v to it (still need to decide - any help will be appritiated). The power supply has 10000uf of total capacitence on each rail (shared by two copies of this circuit...)
I plan to power 6-8ohm speakers with it.
Volume controll will be established using an external, active, pre-amplifier yet to be built
Please - try be realistic. This is my first project - dont kill me
Thanks a lot
Old 16th June 2005, 06:57 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Not sure what to say. It looks OK but I would use a smaller film capacitor for the DC blocker.
If you are using 10K caps in the PSU, I suggest that you have a look at Carlos' snubberized PSU.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th June 2005, 09:54 AM   #3
Heya.
I did put snubbers on the PSU
Ok, I will use a smaller capacitor. How about 4.7uF?
Except that. will it be ok?
Any other things worth adding/changing/removing?
Thanks.
Old 17th June 2005, 10:02 AM   #4
Nuuk's Avatar
How about 4.7uF?
That's fine and do make sure it is a good film type as this is the most important cap as regards sound quality.
Anything else need changing? No, I don't think so but you can always read my thoughts on GC's at Decibel Dungeon.
Old 17th June 2005, 10:47 AM   #5
Thanks dude
Ofcourse I've read your site. An excellent one, I must say!
Old 17th June 2005, 12:55 PM   #6
Hey guys.
I've made some more changes and designed a PCB:
Old 17th June 2005, 02:32 PM   #7
Send a message via AIM to ScottRHinson
Default Re: My first non-inverted gainclone circuit
Originally posted by eranrund
Hello people.
Thanks a lot
Eranrund,
If you don't mind...a couple of suggestions:
1. I don't see a path for DC bias currents for the input. I would move C2 directly accross pin 7 and 8. Also move R2 to the other side of C1.
2. R3 and R1 are somewhat high in value, try 22K for R3, 1K for R1 and 100uF for C3.
3. The National application note for the 3886 mentions the potential need for a resistor accross the input terminals, at the input terminals to prevent oscillations when there is nothing connected to those input terminals. Leave yourself a spot on the PCB for a 10K or a 5K resistor and a small cap (to filter RF) right at the input terminals.
4. Try to get your feedback and input components closer to the 3875 chip on your circuit layout.
5. Provide separate ground returns to the star point of your chassis for signal ground (R2 and C3 return) than power ground (R4, C7, C8, C5, C6). Study the suggested layout for the 4870.
6. The power supply bypass capacitors need to be closer to the chip.
I have just finished putting together a 3886 board. When I first started it up I was using some linearly regulated supplies with test leads that were longer than I would have liked. In the process I discovered how sensitive the high gain, wide bandwidth chip is. I had oscillation issues with that test supply even though I had all of my bypass capacitors as close as physically possible to the chip, my feedback and input circuitry was in a tight loop around the chip pins, and I had separated my signal and power grounds all the way back to the star point.
When I switched to the real supply with shorter, heavier gauge wiring all of these issues went away, but it did give me a better appreciation for the warnings posted in the data sheet.
Scott
Old 17th June 2005, 02:36 PM   #8
Russ White's Avatar
Send a message via Yahoo to Russ White
Quite a good start!
Less pulp more juice Twisted Pear Audio.
Old 17th June 2005, 07:11 PM   #9
Heya.
New versions:
- still need to figure out how to do star grounds - no idea how :-(
i think i'm gonna solder directly to the chip extra capacitors for +ve and -ve. i might solder the feedbacks on it as well.
Please give some more comments
Old 17th June 2005, 07:20 PM   #10
Heya.
New versions:
For an excellent example of star grounding look at the datasheet for the LM4870 (4780?). When doing your layout I suggest the following steps.
1. Place amplifier chip.
2. Place feedback parts next to the pins they are connected to.
3. Place input parts next to the pins they are connected to.
4. Place bypass parts next to the pins they are connected to.
5. Place everything else.
6. Route bypass capacitors with wide traces.
7. Route feedback nets keeping all traces as short as possible.
8. Route input nets keeping all traces as short as possible.
9. Route everything else.
Scott
Inverted GainClone question? 5150ed Chip Amps 35 10th July 2006 08:16 AM
PCB for Inverted Gainclone 2Bak Chip Amps 8 19th February 2004 09:09 AM
Non-Buffered Non-Inverted Gainclone (LM3875) fpr 47K Pot Circuit Wanted krishu Chip Amps 42 5th January 2004 12:14 PM
Circuit questions - Inverted vs non-inverted (again) alvinlim Chip Amps 4 1st July 2003 11:27 AM
Non-inverted Gainclone jpask Chip Amps 1 29th March 2003 08:01 AM
Page generated in 0.15221 seconds (71.72% PHP - 28.28% MySQL) with 11 queries
