| Chip Amps Amplifiers based on integrated circuits |
How do I/ or is it possible to incorporate a 2nd order x-over (300hz) filter between the buffer section and the op-amp ? This would simplify things as I already have 2 of these amps and I would like to run my 3 way speaker actively crossing at 300hz between the woofer and mid-tweet.
Will. |
#2 |
Yes, you can do what you want!
The low pass filter is consisting of the 3K9 resistor and the 1n5 cap, in the showed schematics. But be aware: should you change the value of the 3K9 resistor, you change the input-z and therefore in conjunction with the t-net the overall gain. The input-z in your schematic is 3K9+18K. So, I recommend to calculate the gain with the excel sheet, available here: T-network: the better feedback solution? Kind regards Franz /Edit: be aware of the high pass filter, consisting of 3u3 coupling cap and 3K9+18K. /second Edit: Sorry, I wrote about 1st order filters... |
| Another VBIGC :) | Kermit | Chip Amps | 15 | 26th June 2006 08:05 PM |
| An other VBIGC question | ebijma | Chip Amps | 2 | 3rd April 2004 09:19 PM |
| what does the 1n3 cap in JLTi VBIGC do? | sandro600 | Chip Amps | 2 | 5th March 2004 07:40 AM |
| A Vbigc | Ropie | Chip Amps | 19 | 11th February 2004 05:56 PM |
| VBIGC troubles... | sith | Chip Amps | 17 | 21st January 2004 09:50 AM |
| Page generated in 0.07809 seconds (59.84% PHP - 40.16% MySQL) with 11 queries |
