Yet another pseudo GC in progress
Old 14th June 2005, 07:58 AM   #1
wxn is offline wxn  Lithuania
wxn's Avatar
Default Yet another pseudo GC in progress
200W trafos, 10mF capacitors, non-inverting configuration dual stereo.
Intended for bi-amping, hence the small heatsinks.
The case is actually bottom-up in the pictures, it's an old pc case from some ancient cluster or smth (no openings in the front panel)
Nothing is as simple as it seems
Old 14th June 2005, 08:18 AM   #2
wxn's Avatar
another pic
Old 14th June 2005, 08:19 AM   #3
wxn's Avatar
and another
Old 14th June 2005, 03:15 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
That's a neat idea putting the rectifier bridges on the caps!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 14th June 2005, 04:38 PM   #5
motherone is offline motherone  United States
I like it. I've been planning on using some Copper computer heatsinks myself.. Those look like they're for a Pentium Pro or maybe a socket A chip?
Old 14th June 2005, 04:51 PM   #6
wxn's Avatar
Nuuk: yeah, neat and very compact
motherone: yep, these are Socket A heatsinks. Got them from a local supplier for about 3$ each and they even had fans! Though they were very noisy and as these heatsinks proved to be quite effective up to about 50W output power, I decided to get rid of fans altogether.
Old 14th June 2005, 06:25 PM   #7
jimbo1968 is offline jimbo1968  United Kingdom
I like the zero tolerance of pcb/strip board.
This must limit the choice of components based on physical size. Could you give a rundown of the amp components for those of us who can't yet tell a capacitor from a resistor.
Old 14th June 2005, 06:29 PM   #8
Lucky you! I've been looking for copper socket-A coolers, but haven't been able to locate a deal like that. Most of the suppliers out there will charge you more for the shipping than the heatsinks cost!
You'd think there'd be some good places to get stuff like that here in Seattle, but I must always miss the sales where they clear them out
Old 14th June 2005, 06:31 PM   #9
One thing that comes to mind is have you thought about using thermal epoxy to mount the chips to the heatsinks? It'd be a nice, no-screw method to do it. Might be worth it once you verify that the amp works, and assuming all the heatsinks are isolated from each other and the chassis.
Old 14th June 2005, 06:50 PM   #10
wxn's Avatar
Sure, I'll post the schematic soon. But there's nothing special, usual NIGC.
Yes, I have thought about that. I have even experimented with simple epoxy glue and an insulator (paper towel - about 20microns which was too thick, only appropriate for 30W or so. Sliced mica should do better but I haven't done any experiments yet).
Anyway I will use screws for this project as these heatsinks are a bit small (+-35V supply) and a good physical contact with the case could provide additional heasinking which is important as I'm not planning to put any fans there.
Attached a closeup
Yet another pseudo GC in progressHide this!Advertise here!
Pseudo dual mono PS? Sherman Tubes / Valves 2 22nd September 2006 10:38 PM
Circuit for Pseudo Differential Input? thespeakerguy Analog Line Level 0 6th February 2006 04:43 AM
LM4780 Pseudo SMT Design Gcollier Chip Amps 9 2nd February 2006 09:09 PM
Pseudo co-axial? Nuuk Multi-Way 15 21st December 2005 11:27 AM
pseudo horn ?? ChesterFuzzin' Multi-Way 3 6th April 2004 05:57 AM
