ac voltage after rectification
Old 1st June 2005, 09:31 PM   #1
raif is offline raif  Turkey
Default ac voltage after rectification
Hello everyone,
My multimeter reads 37 v dc after rectification and smoothing with a cap across output terminals. I use a 24 v 330 va transformer and a single secondary connected to four mur 860 diode bridge.
However when I check ac voltage it shows 70 v ac! after rectification. What is wrong?
Thanks.
Old 1st June 2005, 09:56 PM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Default Re: ac voltage after rectification
Originally posted by raif
What is wrong?
You're not supposed to measure DC with the meter set to AC so it's your measurement technique that's wrong.
Old 1st June 2005, 10:14 PM   #3
Default not too fast
I measure dc voltage with multimeter set to dc. The problem is when I check ac voltage across output terminals( obviously, multimeter set to ac) it shows 70 volts ac!
thanks
Old 1st June 2005, 10:20 PM   #4
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Do you have another meter to try? Or a scope to watch?
/Hugo
Old 2nd June 2005, 12:09 AM   #5
homer09 is offline homer09  Canada
homer09's Avatar
Bill is right. measure AC with AC setting and DC with DC setting.
You can't measure AC on a DC signal.
BUT, you can measure how much DC on an AC signal with your meter set to DC.
the reason for this is simple. DC is direct current, AC is DC but alternating at 50/60 Hz. when you set your meter to AC, it assumes its measuring AC, but it will give you about double your DC voltage because there is no switching (which it is assuming there is).
you can measure DC on an AC signal because the AC is switching too fast to be picked up by DC meter.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 2nd June 2005, 09:52 AM   #6
Default meter is set to ac to measure ac
thanks for replies, but I am trying to measure if there is any stray ac voltages after rectification(ripple voltage) and smoothing and I get 70 volt ac reading(meter set to ac). Is this because dc currents are too fast and the meter sees it as ac ?
Old 2nd June 2005, 10:07 AM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
You need a scope, for the reasons Homer ellucidates above.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 2nd June 2005, 11:14 AM   #8
Magura is offline Magura  Denmark
Magura's Avatar
Hmm, is that stricktly so? I was under the impression that a true RMS meter would be able to measure ac on a dc supply???
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 2nd June 2005, 12:05 PM   #9
Jennice is offline Jennice  Denmark
I agree... Testing in "AC" mode should give some ripple voltage only (after the bridge rectifier), but not a seriously high voltage.
The DC mode should tell the intended working voltage after the rectifier.
A scope can tell more, but should not be needed to find the error.
Check for correct connection to the bridge. Otherwise disconnect it and test every one of the 4 diodes to see if one is shorted.
If you do not have a diode tester, a battery and a resistor should work. Current should flow in one direction, leaving about 0.7 V drop across a diode. If you change polarity, no current should flow, and no voltage drop should occur across the resistor.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 2nd June 2005, 12:19 PM   #10
Magura's Avatar
I just checked up on it.
When measuring with a true RMS meter you only measure the ripple when set to measure AC on a DC supply. I have no means of testing if it is so with a non true RMS meter, as I don't have such
Magura
ac voltage after rectificationHide this!Advertise here!
FWCT Rectification ThSpeakerDude88 Tubes / Valves 7 24th July 2007 06:14 AM
rectification nhuwar Tubes / Valves 9 28th January 2007 10:16 PM
Choke input 3 phase rectification voltage? Tweeker Power Supplies 5 13th January 2006 06:08 PM
Negative Voltage with Tube Rectification? commstech Tubes / Valves 7 16th July 2004 05:40 AM
Different type of rectification? officeboy Chip Amps 2 13th February 2004 11:48 PM
Copyright ©1999-2017 diyAudio
