Blown fuse!!!
Blown fuse!!!
Old 4th June 2005, 02:44 AM   #11
StalfoS is offline StalfoS  Canada
Does the attached file make sense for my wiring arrangement?
I notice that there is 20V dc between PG+ and PG-... does this make any sense at all?
Old 4th June 2005, 03:49 AM   #12
homer09 is offline homer09  Canada
homer09's Avatar
nope. you are using your center-tapped (assuming from how you drew your diagram) transfo as a true dual secondary transfo.
refer to brian's user guide, there is a section explaining how to wire center-taps to his rectifier pcbs.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 4th June 2005, 12:47 PM   #13
mrlots2do is offline mrlots2do  United States
mrlots2do's Avatar
This wiring schematic will blow fuse. CT tranny ground not wired to rectifier board.
Old 4th June 2005, 01:10 PM   #14
chris ma is offline chris ma  Canada
chris ma's Avatar
I found this thread which may be useful for you.
http://www.diyaudio.com/forums/showt...150#post627150
The Butcher
Blown fuse!!!Hide this!Advertise here!
amp blown fuse = output offset ? AndrewT Solid State 42 13th November 2014 07:45 AM
Repairing Class A/AB amp with Blown Fuse excetara2 Analog Line Level 5 8th March 2009 10:34 AM
Please help: no sound and blown fuse spendorspain Tubes / Valves 6 11th December 2008 02:48 PM
My Revox B790 has blown its fuse csrote Analogue Source 3 18th September 2008 05:49 PM
ETI480 blown fuse... bezel6 Solid State 1 30th November 2005 12:25 AM
