| Chip Amps Amplifiers based on integrated circuits |
#31 |
Electrons are yellow and more is better!
Diodes for relay coils are very unsensitive. You can use almost anything as long as the voltage rating is enough.
/Per-Anders (my first name) or P-A as my friends call me |
#32 | ||
#33 |
Thanks again Per-Anders. I have now written up the project here
As regards the extra output series resistor, presumably this would be put between relay and ground so that it does not alter the circuit after power up.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#34 |
The relay contact should ge between the power amp input and ground. The extra series resistor should go between the preamp and the power amp.
Check how I have done the mute of my DAC http://home5.swipnet.se/~w-50674/hif...ema_sida_4.pdf Nuuk, if you output IS short circuit proof, it's no harm to brutally short the output to ground. If you aren't sure,100 ohms extra in series is nothing compared to the rest.
#35 | |
#36 |
You must also consider the load in th other end. If it is 10 kohms 68 or 168 ohms will make not much difference but if you have 68 ohms, this will be enough I think for current limiting at startup.
Did you check how I have done my muting?
#37 | |
#38 |
OT: Nuuk, I don't get any pop at all when I switch on the buffer or my gc. I builded a similar gc for my brother, and he gets loud pops. Why is that :?:
Edit: Now that I come to think about it, I have used 8 ultrafast diodes in my gc, while my brother's uses a standard bridge. In my buffer I use 8 byv27-150.
unknown pleasures |
#39 | |
#40 | |
| B+ time delay relay | cbutterworth | Tubes / Valves | 24 | 31st August 2011 01:53 PM |
| Relay delay | Ted205 | Chip Amps | 16 | 24th September 2008 06:44 PM |
| on/off thump - use Time Delay Relay ? | redrabbit | Everything Else | 0 | 29th June 2008 03:01 AM |
| Delay-Off relay | peace brainerd | Parts | 7 | 12th May 2007 04:14 AM |
| Time Delay Relay Tubes | cadman | Tubes / Valves | 8 | 17th December 2002 05:25 AM |
| Page generated in 0.12410 seconds (74.89% PHP - 25.11% MySQL) with 10 queries |
