| Chip Amps Amplifiers based on integrated circuits |
#2 |
What is the purpose of P1?. I think part of figure 12 is missing,if not, both side s1 and s2 should match( r4,r5 and c1).
#3 |
Volumepot?
I think they have just skipped the feedback part because the schematic would be "blurry" ? |
#4 |
If dephaseur is a chip(ie. drv134)that will split the signal,why would two pots be needed. they might add balancing problems.
#5 |
from what i understand, parallel amps need to be closely matched as possible. so they are not driving into each others outputs and causing heat and distortion..
each of the 8 amplifiers has 3 capacitors (1 electrolytic even) and 4 resistors affecting the feedback loop.any variation will cause difference in the outputs and distortion. try and match them as well as you can. I also wonder what may happen if spike protection was to kick in at different times on the different chips. |
#6 |
I was wondering why you would need to repeat the zobel network R3/C3 for each chip.
Also, isn't bridging into 4 ohms a problem.
Greg Erskine |
#7 |
Maybe so you can have each zobel right at the pins of each chip for best effect at HF.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#8 |
| Help my LM3886 | Denis.BR | Chip Amps | 13 | 13th January 2012 06:45 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 06:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 12:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.09768 seconds (79.62% PHP - 20.38% MySQL) with 10 queries |
