paralleling amplifiers. paralleling amplifiers. - Page 2 - diyAudio
Old 31st May 2005, 01:15 AM   #11
neutron7 is offline neutron7  Canada
neutron7's Avatar
Thanks for that circuit macboy, it makes sense now. for some reason, before i did not understand you meant a seperate opamp for the global feedback.
Old 31st May 2005, 02:48 AM   #12
jcx is offline jcx  United States
the outer loop op amp has to be slower than the paralleled output op amps - not hard when you're using 100 MHz cf amps inside
a gain of +2 in the output amps makes for easy R matching and doesn't amplify offset too much
load C isolation may still need attention, but a high frequency lossy ferrite or the usual load isolating resistor+inductor (outside the feedback loop!) should work
Old 9th June 2005, 09:14 PM   #13
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
What about something like this: similar to macboy's schematic. Using paralleled amps at unity gain inside the feedback loop of an opamp. Would the paralleled amps still need output resistors?
Old 10th June 2005, 01:32 PM   #14
macboy is offline macboy  Canada
Yes. But you can get away with small ones, like 0.1 or even 0.05 ohms.
Be very aware that this can only be done if the amps that are used are unity-gain stable. (I only mention this because the National LMxxxx chip amps are not, and I just know that someone will wonder if it can be done with them. Answer: No.).
If you are going to use unity-gain stable amps, then you can hook it all up like the following, and eliminate the extra opamp on the input. Note all four opamps in the schematic are identical power opamps. (also note that this schematic generally assumes voltage-feedback opamps. With current-feedback opamps, you can't use the cap across the feedback resistor, and you can't configure it for unity gain by tying the output to '-' input).
Old 10th June 2005, 02:12 PM   #15
jackinnj is offline jackinnj  United States
jackinnj's Avatar
fwiw -- for the first set of paralleled LM4780 amps I built I matched the resistors to 0.1% -- and it worked quite well. on the second set with production PCB's I matched to 0.01% (inside of 1/10th of an ohm) -- the distortion was about 0.001% lower -- which probably doesn't mean a whole lot -- since the world of probablility, noise and statistics...is the world of noise, probability and statistics. The direction was better, that's all I can conclude, and a bag of 100 Yaego metal film resistors isn't that expensive.
I used an HP3478A DVM for the matching -- these are now cheaper than a new Fluke 177 handheld (although you are tied to the A.C. line).
Old 11th June 2005, 05:43 PM   #16
ljordan is offline ljordan  United States
Default Great ideas, I too would like to build a 4 to 8 piece tpa amp..
jcx:...load C isolation may still need attention, but a high frequency lossy ferrite or the usual load isolating resistor+inductor (outside the feedback loop!) should work .
I want to avoid using any resistors in series with the load.
Would I just use a ferrite cylinder as a core for several loops of output wire?
Are these the snap-together type seen on power power lines?
Can some one post some examples?
What would be some starting point values for components in these two options for isolating the load C from the amp outputs?
My prototype TPA will oscillate if I do'nt keep the headphone cable short and still.(I use 24 ohm phones and no resistors, btw)
Lewis
Old 11th June 2005, 07:37 PM   #17
I just tried one of those snap on ferrite tubes around the three (L,R Grd) as they come out of the chip.(just one around all 3)
I'm whipping the long cord right now. NO buzzing.
Lewis
Old 12th June 2005, 12:29 AM   #18
jackinnj's Avatar
Default Re: Great ideas, I too would like to build a 4 to 8 piece tpa amp..
good luck. the purpose of the resistors isn't parasitic elimination -- that's for the RC network consisting of the 2.7R/100n combo -- let us know how long your chipamp lasts.
Old 12th June 2005, 06:06 AM   #19
I meant the TI output 10r (spec'ed in the eval.brd pdf) ,not the sharing Rs in these parallel diag's.
Lewis
Old 12th June 2005, 06:13 AM   #20
I am only using a single chip for now and it oscillates for any reason with out the output R. With short headphone wire I got it to sound better wo the R. Then I tried the ferrite and its seems I have found a way to eliminate the 10r
Lewis
paralleling amplifiers.Hide this!Advertise here!
Paralleling transformers??? dfdye Chip Amps 10 30th January 2006 05:26 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Paradigm amplifiers? Anthem amplifiers? Corn-Picker Solid State 2 24th January 2004 03:10 AM
Many smaller amplifiers vs. bigger amplifiers. djdan Solid State 9 17th September 2002 04:40 PM
paralleling mosfets in BLS SteveG Pass Labs 14 7th February 2002 09:20 PM
Copyright ©1999-2017 diyAudio
