| Chip Amps Amplifiers based on integrated circuits |
In an earlier post by Carlos he showed some pictures of a grounding scheme he was using with some BrianGT boards. However I can't seem to find it even though I searched for it. Aslo I'm not sure I completely understood it. Is the attached picture an accurate depiction of waht Carlos was suggesting?
#2 |
It's been posted here: http://www.diyaudio.com/forums/showt...246#post617246 and it works well, especially with LM4780 boards powered from a common supply.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 | |
Banned
Corrected. |
#4 | |
Thanks Carlos!!!!! It's clear now! I was confused about the what you did with the extra pair of the power supply's PG+ & PG- but I see you just leave them empty. Thx again! |
#5 |
By this method of grounding exist theoreticaly little crosstalk between channels, 'cos any ground wire have zero resistance.
#6 | |
-d |
#7 | |
#8 |
Yes - you know my english
#9 | |
Banned
Get those boards close from each other. Then use a thick solid core wire (1.5~2.5mm) to join the two boards. Coming from the PSU to the center of that wire I use multi-strand 2.5mm copper. This is all normal electrical wire, no need to get fancy.
#10 | |
Banned
Yes, it's a common PSU for two channels. Even then, it's still better than using a single LM4780 chip for stereo. It is also the way to make a silent amp, no hum. I have been explaining this for years... glad that someone had the brilliant idea to make a sketch. ![]()
| grounding scheme | Leolabs | Solid State | 2 | 12th September 2006 02:43 PM |
| Grounding Scheme within a DAC | 5th element | Digital Source | 29 | 15th June 2004 09:23 PM |
| PCB Grounding scheme | dexter | Solid State | 2 | 27th May 2001 02:48 PM |
