LM1875 from Silicon Chip Your Impressions
Old 18th May 2005, 06:48 AM   #1
Angel-Baby is offline Angel-Baby  Australia
Default LM1875 from Silicon Chip Your Impressions
Hello Just after peoples impressions on the LM1875 design from silicon chip personally I think it could be a lot smaller in design than it is, but they say it works ok the reason I am asking for your impressions is I wish to make a few of these LM1875 amps and just stumbled across the Silicon chip design and thought I would post here for feedback.
Thankyou any help much appreciated
Cheers
AB
P.S. here is the link for the amp
http://www.siliconchip.com.au/cms/A_103236/article.html
Old 18th May 2005, 07:52 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I guess the name gives you a clue. 'Schoolies Amp' is probably aimed at students and by making it not too compact, it's easier to build and see where everything goes.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 19th May 2005, 11:09 AM   #3
paulmac is offline paulmac  Australia
paulmac's Avatar
I made a few 1875 modules to power my main amp a few years ago, and basically followed the data sheet. I built mine (5 channels) on individual bits of veroboard with no hassles.
In my opinion (which has been influenced by ears that are not golden....) they sound great.
The volume control doesn't go past half way.
I've also built an LM3886 amp that also sounds just fine, also on veroboard. It's in use as a "loud" amp when my wife has a singing session.
I've never put the two head to head to try to compare the sound of them, because (a)I couldn't be bothered, and (b)because I've been suitably amazed with both of them for their simplicity, their ease of use, and their lack of noise.
If you want simple, and it's only for the lounge room, go for the LM1875. With only five pins, it's hard to stuff it up. Just make sure you have a nice power supply reserve behind it, something like CarlosFM's "snubberised" setup, and you'll be fine.
Having said all that, I'm going to re-do my amp with some 3886s one day. That will be after I make the 200w "louder" amp with 6x 3886s for PA use....
Too many projects, not enough time...
Paul.
Old 19th May 2005, 01:14 PM   #4
AnthonyPT is offline AnthonyPT  Australia
Send a message via ICQ to AnthonyPT
Rod Elliott's ESP site does a 1875 circuit
board and it is more compact and has
two amps on it. That is if you want a readily
available 1875 low hassle option and are
not going for a hardwire attempt.
http://sound.westhost.com/project72.ht
AnthonyPT
Old 19th May 2005, 02:58 PM   #5
NITRO is offline NITRO  Turkey
Hi
I've designed 1875 PCB that size is almost half of the silicon chip design (96 x 26 mm. including bridge rectifier, two 4700uF caps and remaining components and still got a empty space ). If you are interested i can send PCB drawing to you.
Regards.
Türker
Old 20th May 2005, 04:37 AM   #6
Hello everyone thanks for all your replys much appreciated I got given 10 of these lm1875 chips from a friend at a electronics shop that has now closed thought I would put them to good use and yes NITRO I would love to have a look at your lm1875 design if thats ok please e-mail when you get a chance
Thanks again everyone for your feedback
AB
Old 20th May 2005, 07:19 PM   #7
carlosfm is offline carlosfm  Portugal
Banned
I always liked the LM1875 very much.
That's what I use on my bench, always listening to it.
LM1875 + snubberized PSU.
I have tested this amp on my main system, with my difficult Epos ES11 speakers and I could not believe... it drives them quite well.
Also, it's small, I can take it everywhere.
It made quite a success on this year's new year's day party, with an old Philips portable multibit CDP (tweaked) and a pair of (tweaked) Boston speakers I have.
Who wants to make a small, simple amp should try these chips.
Beware, you can end up with a (low power) high-end amp.
Old 20th May 2005, 07:30 PM   #8
Hi Angel-Baby,
Here's my PCB layout for lm1875,i hope you'll like it.By the way there's one important point on layout.There's one hard to see SMD resistor between IC pins 4 and 2 as a feedback/gain resistor that directly soldered to pins.But if you don't have any SMD you can use conventional resistor in the same place because there is a enough space in that area.
Old 20th May 2005, 11:17 PM   #9
Hello again and thanks for all your replys much appreciated and thankyou nitro for your layout I am going to sit down today some time and start building some of these
AB
Old 27th May 2005, 10:29 PM   #10
michal is offline michal  Canada
Carlos, what schematic is your LM1875 amp based on?
I am building an amp with LM1875s and I'd like to get the best sound quality possible. I've made one some time ago using the data sheet's schematic, but I guess there's a better way.
Michal.
LM1875 from Silicon Chip Your ImpressionsHide this!Advertise here!
Silicon Chip ULD amp Greg Erskine Solid State 20 18th March 2012 03:47 PM
Silicon Chip Ultra LD Mk2 Module pheonix358 Solid State 0 30th July 2008 05:25 AM
HEI from June 98 Silicon Chip AKSA Solid State 3 1st March 2008 06:31 AM
(Aus) Parametric EQ from Silicon Chip 07/96? Cloth Ears Subwoofers 3 20th April 2007 12:19 PM
Silicon chip studio 350: HELP NEEDED (please!) 81gl Solid State 15 2nd October 2006 11:41 AM
Copyright ©1999-2017 diyAudio
