Old 11th May 2005, 12:59 PM   #1
Default 3 paralleled opa541's
how much power should i expect in general when i parallel 3 opa541 chips with +-21DCV(42.6V total) and drive a 2 ohm sub (dual 4 ohm voice coils hooked in parallel to give 2 ohm)
Old 11th May 2005, 01:37 PM   #2
macboy is offline macboy  Canada
Accourding to the datasheet, the output swing will go within about 4 V of each rails so the maximum voltage that this could drive will be about +/- 17 V. A sinewave at +/- 17 V (that's 34 V p-p) is 12.0 V rms. Convert that to power into 2 ohms, and you get 72 W rms (P = V^2 / R). Given the currents that you will be driving, you could easily get away with just two '541's instead of three, and still get the same output power. Or if you kept three, you could increase the power supply voltages to get more power.
DAC 1955 paralleled fabiodord Digital Source 9 25th September 2008 10:20 PM
paralleled rectifiers for +/-v ? snkby Parts 4 23rd May 2006 03:24 PM
Paralleled Toroids? theAnonymous1 Solid State 5 19th July 2004 02:40 AM
DAC with paralleled TDA1541's sugano Digital Source 0 2nd May 2003 08:14 AM
Zen v4 with paralleled FETs Stanislav Pass Labs 15 4th March 2003 10:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
