Old 8th May 2005, 04:13 AM   #1
ctardi is offline ctardi  Canada
Send a message via MSN to ctardi Send a message via Yahoo to ctardi
Default Opa549
I'm just learning about making amplifyers. Here is what I have come up with using information from the datasheets, and bigmike216. The input power will be about 18V. The of each channel will first go thru the DRV134, and also a preamp that has not been decided yet. What all changes will need to be made?
Old 8th May 2005, 06:58 AM   #2
first off, the voltage will be + and - 18v, before rectification..
When I have the pcb's made, it'll be easy as pie to assemble it, won't have to worry about how to wire anything
do a forum earch about bridging, also search for opa549 and drv134, there's a ton of information.
Talk to me on messenger or something and I'll help you out
Old 8th May 2005, 04:09 PM   #3
neutron7's Avatar
if you must use a decoupling capacitor, use it before the DRV because any difference in capacitance will result in different low frequency response on the 2 sides of the bridge. then you will get asymetric output at those frequencies affected
Old 8th May 2005, 04:21 PM   #4
paulb is offline paulb  Canada
Why would the capacitance be any different? If you're referring to the tolerance of the capacitors, it will be a very minor effect on frequency response.
But there should be a capacitor, and resistor to ground, before the DRV134.
Old 8th May 2005, 04:48 PM   #5
I was talking, but it was a one sided conversation. (you left signed into messenger)
A cap and resistor has been added before the 134...thanks. Other than that, does anyone see anything else majorly wrong with it?
Old 8th May 2005, 06:32 PM   #6
the capacitor and resistor need to be on the input.
What are you planning on doing for a power supply?
Old 8th May 2005, 07:43 PM   #7
i know... they are on the input in version 1.2
Not sure about the power supply right now, still looking for a transformer.
Wtb Opa549 HIPCHECK Swap Meet 0 14th April 2008 01:07 PM
Opa549 Treefingers Chip Amps 1 23rd September 2005 08:37 PM
Fs: Opa549 bigmike216 Swap Meet 3 26th August 2005 12:08 AM
OPA549 GC for Car abid_rehan Chip Amps 11 13th June 2005 04:09 PM
Page generated in 0.09035 seconds (77.33% PHP - 22.67% MySQL) with 11 queries
