Old 6th May 2005, 05:18 AM   #11
Originally posted by indoubt
I've used a PC PSU to power an old carradio. The PSU is modified with a 10.000uF cap, a small bypass cap and a 17Watt resistor on the 5V to keep the supply from shutting down.
It works, it even works reasonable well after adding the capacitance but I don't think it will be as good as a regular supply. It remains a little noisy alhough the fan drops in speed after a minute or so because the supply is operating far from max.
Don't connect the other wires to get 24 Volt, I think they have a common ground ro zero and then you shortcut the thing instantaniously. different PSU might have different topologies though.
Did you have any problems before you added the Cap? Noise, underpowered?
Old 6th May 2005, 03:58 PM   #12
dnsey is offline dnsey  United Kingdom
Did you modify your PSU at all? What rating? 250 -500w?
It's an old 150W AT supply with no mods at all (apart from removing the unwanted output wires). I've used another to power an LCD display and QH lamp (+12v) without any problem.
Computer supplies have the great advantage when experimenting of foldback limiting and shutdown if shorted or overloaded
Old 6th May 2005, 06:21 PM   #13
arte is offline arte  Sweden
Computers PSUs are great imo. The only limit is the low voltage (you cant draw much AMPs between the -5 <-> 12v).
I have it to power my car amplifier driving two speakers with 12".
Its a cheap one but still its capable of deliver 7-8 amps constant (i have tested with a peltier element).
And as someone mentioned, you can really mess with them - they hardly brake.
Its even cheaper then bying a trafo with that rating, and on modern ones the ripple is very low.
So, use it!
computer power supply? bostonswoop Chip Amps 29 25th April 2009 03:57 AM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
Page generated in 0.08589 seconds (62.43% PHP - 37.57% MySQL) with 10 queries
