Old 28th April 2005, 05:23 AM   #1
Default Is This circut suitable for an OPA541?
Attatched a schematic.. is it suitable?
Would the same curcut work with the opa549 and 548, provided I made the proper adjustments to the pin numbers of the chip in the schematic?
Old 28th April 2005, 01:34 PM   #2
macboy is offline macboy  Canada
Looks like you have a gain of 22, which is way too high for the OPA541. Unless this is a subwoofer amp, reduce the gain, or your high frequency response will suffer. If you need more gain, add a simple pre-amp stage with a good quality opamp.
Old 28th April 2005, 03:05 PM   #3
what is a suitable gain?
Old 28th April 2005, 03:38 PM   #4
The gain-bandwidth product of the OPA541 is 1.6 MHz. In order to keep the audio band frequency response of the amp clear of the effects (in both amplitude and phase) of limited bandwidth, I would recommend keeping the bandwith above 100 kHz. That means that the maximum gain should be around 16. The OPA549 is even more restricted with its GBP of 0.9 MHz. The National LMxxxx chips generally have a much higher GBP (e.g. 8 MHz for LM3886) so they can be run at higher gain than these TI chips.
circut card cleaning dognut Parts 7 22nd April 2009 09:04 PM
New to Circut design:help! zolthoff Power Supplies 2 18th March 2007 02:17 AM
Circut bending guitargully Instruments and Amps 4 20th July 2005 08:31 AM
Cap, Res, Ind Circut Calculation Software Allan Multi-Way 0 26th March 2004 09:28 PM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Page generated in 0.18320 seconds (30.63% PHP - 69.37% MySQL) with 11 queries
