Old 26th April 2005, 03:17 AM   #21
XELB is offline XELB  Portugal
Carlos, you have 8 Ohms speakers. Don't you ?
Mine are 6 Ohms, and normally I test the amp with 4/2 Ohms speakers(this ones have 5 drivers but 98dB sensitivity).
Do you think 10,000uF per rail will work fine with this speakers?
If you want power you must add control
Old 26th April 2005, 03:47 AM   #22
cjd is offline cjd  United States
Originally posted by metalman
Let me see if the XGC likes it!
Originally posted by carlosfm
Do that, try it.
The only reason I want to parallel before the X (SuSy) circuit is the speakers will be rather low impedance... between 2 and 3 ohm I think very likely. May dip below but I think I can keep it above 2. I also have a few of the LM3886 to mess with, and will likely wire up one with those before the LM4780's. There I can obviously go with this circuit as-is. Looking forward to it.
C
Old 26th April 2005, 05:05 AM   #23
neutron7's Avatar
carlos, why dont you try a tracking pre-regulator version . It is a cheap way to get quite improved noise performance. since the pre regulator is referenced to the output of the main regulator. the main regulators input also benefits from the regulation of its output,. (and who knows maybe the snubberization as well ) and the error amplifiers in those things need as much help as they can get, they are about the quality of a 741!
i hope that makes some kind of sense.
you need to have a bit more of a voltage drop though.
you just need another 338, a cap and 2 resistors per rail.
its on page 12 of here
http://www.national.com/ds/LM/LM138.pdf
Old 26th April 2005, 06:29 AM   #24
Mikett is offline Mikett  Canada
Try some LT1083s which have better HF impedance characteristics than the LM338 which are not as high performance. The snubber values will need to change I imagine. The LT1083 is unfortunately more expensive though.
Here's one example with no snubbers.
http://shine7.com/audio/gainclone.htm
Old 26th April 2005, 07:30 AM   #25
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Carlos
Secondary on T2 is shorted in the diagram.
Old 26th April 2005, 09:30 AM   #26
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Carlos, does the regulated 3886 still run hotter with your latest regulated supply?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 26th April 2005, 09:49 AM   #27
nina is offline nina  United Kingdom
The LM338 reg Ic is more expensive than the LM3875 power IC !
Carlos,
Seems we also put the chipamp to its limitation now. Just wonder what next innovation you will contribute to this forum
How about this:
- Parallel chip amps with IC driver/buffer
- Chipamp as driver to Mosfet power stage
- Integrated (Chip)amp with NOS DAC
- Chipamp with High WAF ** Important*
( WAF = Wife Acceptance Factor )
Hee hee hee
Old 26th April 2005, 10:32 AM   #28
NealG is offline NealG  United Kingdom
Hey Carlos, thanks for sharing this!
It's been a while since I changed my clone, I will dust off the soldering iron and get to work!
All the best
NG
Old 26th April 2005, 10:53 AM   #29
Nuuk's Avatar
Yes, I'm going to try it as well. I'll sell the Krell to raise money for the extra parts! (Only joking Uncle Carlos but I will need to order the extra caps)
Old 26th April 2005, 01:03 PM   #30
shusha is offline shusha  Croatia
shusha's Avatar
Send a message via ICQ to shusha
I don't know. LM338 cost me less then LM3886, while both of them cost practically as one LM3875. In my local store(s).
LM338 = 4,4€
LM3886 = 5,3€
LM3875 = 9,3€
Page generated in 0.12280 seconds (76.53% PHP - 23.47% MySQL) with 11 queries
