Old 24th June 2005, 06:08 AM   #201
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
What about class A amps? How this apply to them? What capacitance to use behind the regulator in lets say Aleph 30 or Aleph 5 situation?
Old 24th June 2005, 06:04 PM   #202
Banned
Originally posted by grege
From my point of view, the regulated supply has a permanent 8 volt voltage drop which is probably greater than that of the unregulated PSU.
I meant the voltage drop on the chip's pins, on the amp.
On an unregulated PSU that is modulated with the music, depending on how much current the amp is asking from the PSU.
Old 24th June 2005, 06:06 PM   #203
Banned
You don't need more than 10,000uf before the reg.
Old 24th June 2005, 09:05 PM   #204
Greg Erskine's Avatar
I understood what you meant, I was just trying to say that to achieve a sag free PSU, we have to add a regulator that permanently drops, in this case 8 volts. The power used by the regulator is not avaliable to the amp. That's all.
Greg Erskine
Old 24th June 2005, 09:36 PM   #205
homer09 is offline homer09  Canada
homer09's Avatar
i think logically, less regulated power is better than more but sagging power.
also, chips have a voltage limit, so if you like listening to them at say 32 volts, use a 40V trafo regulated down to 32. so in this case, yes those extra 8 volts are not available, but you dont want them to be anyway.
but i see what you mean if you are using the same trafo for both situations.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 24th June 2005, 10:35 PM   #206
Banned
Old 24th June 2005, 10:48 PM   #207
homer09's Avatar
haha, i know these are way to high for LM series chips. i just pulled numbers out of the air. no need for fire warnings!
Old 24th June 2005, 10:50 PM   #208
Banned
Didn't you find out yet?
With a 40V trafo you will get 56V
Old 26th June 2005, 06:07 AM   #209
I wasn't a few days here, but I see - neverending story .
Old 26th June 2005, 10:22 AM   #210
Franz G is offline Franz G  Switzerland
Franz G's Avatar
I wish, you still have a happy and sunny sunday, regardless of neverending stories
Kind regards
Franz
Page generated in 0.10360 seconds (79.76% PHP - 20.24% MySQL) with 11 queries
