Old 22nd April 2005, 10:47 PM   #1
Send a message via AIM to sauuuuuce
Default Biamp 3875 problem
Here's the deal.....running a biamp.......active crossover works fine. The amps were fine individually. When pumping music through them they both distorted badly. Also if you let that mess go for a couple of minutes the HF amp shorts from V+ to V-. Aby ideas? Need more info? I have a 600VA toroid feeding a full bridege then to 2200uF caps for PS.
It wouldn't be what it is, if it wasn't what it was
Old 22nd April 2005, 10:53 PM   #2
ingrast is offline ingrast  Uruguay
Default Re: Biamp 3875 problem
Originally posted by sauuuuuce
... Aby ideas? Need more info? ....
Yes, please more info on your setup.
Rodolfo
Old 22nd April 2005, 10:58 PM   #3
pinkmouse's Avatar
sauuuuuce, please don't swear, I get really annoyed if I have to manually edit posts.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 22nd April 2005, 11:08 PM   #4
sorry about the swearing
I'll get a scematic up shortly
Old 28th April 2005, 06:11 PM   #5
Default schematics
LF side is same just switch the HPF for a LPF
Old 28th April 2005, 06:24 PM   #6
Banned
You have a gain of 2 on the LM3875.
Old 28th April 2005, 07:15 PM   #7
Default oops
The feed back resistor is supposed to be 20k
Old 28th April 2005, 07:31 PM   #8
Default Re: schematics
There are some observations:
First. Do you need such low gain (2x)? I have not tested this type of monolithic amplifiers at gains much lower than recommended (I've got down to 10x with no problems, not below). There exists the possibility of instability, and I suggest to check changing R14 from 1K to at least 10K, or 18K - 22K as recommended and see what happens.
Related to the previous point and with respect to the HF amplifier which is the one depicted, you have a 1 nF DC decoupling capacitor (C5). Not going into details, this converts the amplifier to an (unintended) voltage follower at low frequencies exacerbating the potential instabilities.
C5 (and the corresponding one for the LF side) should be fairly large (about 100 uF), and since they must be electrolytic to achieve this value, should be polarized. A handy alternative is to return the (-) side to the -V rail, but that will couple and amplify any ripple there, so it is better to devise an auxiliary simple zener regulator for biasing. (unless you have the -V rail already regulated and clean).
Lastly, don't forget to bypass the + and - rails to ground with 100nF and at least 10 uF on each side as close to the chips as practical. You may also want to try Carlos's snubberizing.
Hope some of this helps.
Rodolfo
Edit:
..The feed back resistor is supposed to be 20k..
Sorry I posted before your correction. Except for the gain issue, other points hold.
Rodolfo
Old 29th April 2005, 02:28 AM   #9
Fossil is offline Fossil  Singapore
sauuuuuce,
when u said u test individually, do u mean with or without the active xover?
Old 29th April 2005, 03:06 AM   #10
Tested without active xover. so just the LM3875 circuit. I am figuring the problem, or at least part of it, roots in joining the circuits. just can't pin point it....I could be wrong
5W Zen for biamp tweeter Kanga Pass Labs 16 2nd February 2010 10:58 PM
acoustst 2+1 biamp? Williams Audio Planars & Exotics 8 30th July 2007 05:42 PM
Biamp: Wich fc ? Higo Multi-Way 18 5th August 2003 12:24 PM
To Biamp or not to Biamp, that is the question??????? Apogee Pass Labs 70 12th July 2002 12:34 AM
biamp with active x-over Fossil Solid State 9 10th October 2001 02:10 AM
Page generated in 0.16474 seconds (53.92% PHP - 46.08% MySQL) with 11 queries
