| Chip Amps Amplifiers based on integrated circuits |
#31 |
There was a power-amp by Musical Fidelity, model A370, that also used an LM318 on the first stage, boosted by ten MOSFETs at the output.
Apparently it was class-A, but I am not too sure of that. It was released in the mid '80s, if I am not wrong, and it seemed to get good reviews. Carlos |
#32 |
Hi, Carlos
I have quoted the similes with my circuit of A370 here: MY_REF technical description The mosfets are polarized to 1A total, then it's class AB... This circuits are not "STASIS"... ciao Mauro |
#33 |
Hi Mauro and all other,
I've seen Mauro's work here and find it quite intersting to build the PC/CC. Therefore, I made a PCB layout and etched them yesterday. Now I'm waiting for the parts to stuff the board. I'll inform you about the results then as soon as possible. ![]() Raphael |
#34 |
This is very fascinating. Am I understanding the basics correctly:
First stage: a voltage gain stage without current gain, as current gain affects noise Second stage: a current gain stage operating on the high signal to noise ratio produced by the first stage |
#35 | |
Hear the real thing! |
#36 | |
I have tried a different yet similar approach. I have prototyped the circuit shown below using an LM3875. It works just fine (and sounds very good, too!) using a tube "front-end" (actually a 12b4 SE preamp!).
The circuit is perfectly stable as far as the drive impedance (Rs) is high enough compared to R1.
| Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? | danielwritesbac | Chip Amps | 20 | 30th November 2008 12:27 AM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Simplified LM3886 amp pcb "organic" style | Groundloops | Chip Amps | 0 | 23rd May 2006 02:46 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Page generated in 0.09244 seconds (71.19% PHP - 28.81% MySQL) with 11 queries |
