Equalizing input volume
carlosfm said:
Change it for 10x gain per chip.
That's 2.5x gain.
Sorry I meant 2.7k instead of 2k
I really dont want to do that because I will have to change resistors for 20 chips.
I will remove the resistors from feedback and feedback to ground in the opa2134 and buf634 preamp then replace it with wire.
Do you see any problems?
:eek:
Anyway, you have a higher than normal gain for a power amp.
It's your choice, but keeping things this way means that you are not going to be able to connect any "standard" preamp to your power amps.
Change the 2.7k resistor for 5.6k, that should be enough (~1.5x) , I think you don't need to go unity-gain.
