| Chip Amps Amplifiers based on integrated circuits |
Hi all;
I just made an amplifier with two LM3886 in parallel configuration with servo circuit.But i have some thermal problems.Circuit draws 200 mA quiescent current from each rail.With the +/- 33 V of supply voltage idle thermal dissipation exceeds 13 Watts.I think that it's not a normal.Anybody encountered this problem before? Waiting your comments. |
#2 |
Most likely cause is oscillation.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Electrons are yellow and more is better!
Can you make one LM3886 work properly?
How does your design look like? Is it taken from AN-1192? How much DC offset do you get? Which value have the resistors from each output? 0.1, 0.22 or 0.33 ohms?
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Hi Nitro
The max. idle currnet for ONE LM3886 is 80 mA (and I have never really seen it this high) so for two it should max. be 160 mA + additional circuits. Either you have to much DC-offset (if your DCServo is working OK you should not have this problem.) or you have osc. Having worked with 4 x LM3886 in bridged/paralle configuration I typicall ended up with around 250 mA idle current so your 200 mA for just two LM3886 seems "wrong". Have fun Thomas |
#5 |
Hi Thomas
I'm still making modifications on the circuit from yesterday, and finally got 150mA at idle.I think that it is a good value for two ics.Maybe i can lower this current 100-200 mA less, stil trying.Actually not a high value for home use but im gonna use this at car so the dissipation must be low. Thanks for all replies. Türker |
| Quiescent current question? thanks | crippledchicken | Solid State | 29 | 18th June 2005 09:58 PM |
| quiescent current different on both channels? | crippledchicken | Solid State | 6 | 21st November 2004 02:55 AM |
| P3a No quiescent current! | PetarLD | Solid State | 9 | 17th February 2004 01:20 AM |
| LM3886 and it's quiescent current | Toster | Chip Amps | 5 | 5th May 2003 10:23 PM |
| Quiescent Current | JohnClark | Solid State | 13 | 16th November 2001 08:20 PM |
| Page generated in 0.10795 seconds (65.76% PHP - 34.24% MySQL) with 10 queries |
