Which Chip Better
Which Chip Better
Old 18th April 2005, 12:56 AM   #1
thomasfw is offline thomasfw  Hong Kong
Default Which Chip Better
Dear All,
Any one has experience to tell, LM3868 and LM3875
is better in "HI FI" point of view (with same output)
in case :
Making :
1) Classic GainClone ?
2) PBA 200
Thomas
Old 18th April 2005, 02:43 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Should be LM3886 not LM3868,right???
I havent actually hear the sounds of the both under same circumstances,which mean i havent make any AB comparison between them.But there's 1 thing for sure,driving capability of LM3886 is better than LM3875.U cant tell LM3875 to drive a nominal 4 ohms load when operating at high supply voltage.
So,for me,i will use LM3875 for classic Gainclone but operate it around plus minus 18V,and for BPA200,LM3886 of course!
Old 18th April 2005, 06:46 AM   #3
nina is offline nina  United Kingdom
It depends your speaker (sensivity), type of music you listen to and size of the room.
I had listened my friend's PBA200 for some times last years, I preferred LM3875 Classic GC (25W) as more detail, clearer, better transient responses -- particularly if you have high-sensivity speakers.
Old 18th April 2005, 06:46 AM   #4
Default Re: Which Chip Better
Originally posted by thomasfw
Dear All,
in case :
Making :
2) PBA 200
Thomas
How come I forgot to answer to your question -__-"
In my opinion, in case of:
Classic GainClone ---> LM3875
PBA200 --> LM 3886
Old 18th April 2005, 08:16 AM   #5
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I agree, if you don't need the extra power, ie you have easy to drive speakers, the LM3875 does just edge it as regards sound.
There's a touch more 'delicacy' with the LM3875.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th April 2005, 08:55 AM   #6
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Which Chip Better
The 3785 is better inverted, the 3886 non. But the OPA549 inverted is better than both...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 18th April 2005, 09:03 AM   #7
dw1narso is offline dw1narso  Indonesia
...and with the right rail voltage supply... usual living-room size... and the kind of music you play... that high-sensitivity requirement "trade-mark" for LM3875 do not always necessarily right...
My LM3875 NIGC with +/-18V AC secondary (about +/-25VDC rail) with 2x1500uF per-channel, drive 86db/4ohm Dyanudio Audience 40 with pride... (I listen to jazz, classical, acoustic, rocks... but not synthesized-house music...)
David
Which Chip BetterHide this!Advertise here!
Which Chip AMP you like most? dynabok Chip Amps 154 12th December 2012 01:23 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 04:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 01:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Hot chip! batkey Chip Amps 1 14th October 2004 11:54 AM
