| Chip Amps Amplifiers based on integrated circuits |
Hi there,
A friend wants to take the output of a CD player and drive 4 amps simultaneously. These would be small amps with their own passive volume controls (either 4 GC's or 4 Sonic Impact T-amps) In addition, he would like to add a passive 'master volume control'. I wonder if something like this can work: CD -> pot (100K?) -> op amp buffer (OPA2227?) -> 4 amps in parallel In the final stage, the signal out of the buffer will simply be split to the 4 amps, which in turn will drive 4 pairs of ceiling speakers for background music. I suspect a buffer is necessary to keep the input impendence seen by the amps from being too high. Does this have a chance of working? Will the volume/frequency response of the other amps change appreciably if the volume of one of them is adjusted? If this doesn't work, can someone suggest an approach? Thanks, Dennis |
#2 |
Your approach sounds fine. Adjusting the volume on one amp should not affect the others. The only reason I can think of all hand is if the buffer op amp. sees too little impedance and the signal is dropped some due to loading.
-SL |
#3 |
opamp in follower mode will give a low output inpedance (a few 10's of ohms). add a 100R in series with output. Make sure all the power amps have a DC blocking capacitor on their input. Otherwise the input bias of each amp will interact and screw up all the designers calcs.
regards Andrew T. |
#4 |
AD811 works great for this application, or you could use the BUF634. Just make sure that you have lots of bypassing capacitance by the chip.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
Gentlemen,
Thank you for all your suggestions! I'm curious if there's anything specific about the AD811 that may make it better than the BUF634 for this application? (Or it is just that AD811 sounds better? )One question regarding adding some resistence to the output of the buffer. Is it to ensure that the output impedence doesn't get too low relative to the input impendence that follows? For the input pot, how high can one realistically go? I have a nice 250K stereo log pot but I suspect that may be too high. Thanks, Dennis |
#6 |
I know of 2 reasons for the inline resistor 1. to reduce the damaging effects of a short on the output, pulling plugs with gear live! 2. to isolate capacitance from the opamp output stage. Another sugestion. Insert a high value (1M to 2.2M) resistor from live to ground at your output socket, to ensure 0Vdc at the output if this stage or the next stage has a leaky coupling capacitor.
regards Andrew T. |
| 500W+ amps for driving your subwoofer | Cloth Ears | Subwoofers | 27 | 25th March 2007 11:54 PM |
| Driving a REGA Planar 3 with my CD player | cukkurullo | Analogue Source | 0 | 23rd February 2007 08:03 AM |
| problems when driving a p3a direct from CD player | Mark25 | Solid State | 1 | 18th November 2006 02:16 PM |
| Serious P.S. question - Driving 2 x 350w amps @ 4 ohm | mr_squeegs | Solid State | 10 | 18th September 2006 12:34 AM |
| Behringer DEQ ok driving multiple loads | brucemck2 | Subwoofers | 0 | 18th January 2006 09:49 PM |
| Page generated in 0.09225 seconds (78.61% PHP - 21.39% MySQL) with 10 queries |
