Old 13th April 2005, 10:13 AM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default 3886 DC offset (again)
I have completed my second 3886 stereo GC.
On the first, I had 19mV offset on each channel. On the new one, I have 40mV on one channel but 1.2 volts on the second. All four channels are built with identical circuits, ie inverted circuit, 270K feedback, 12K input, wire from NI to ground, Carlos FM snubbered PSU.
I have read all the results from a search on this topic but couldn't find anybody who had got such a high DC offset. Is this down to the chip? I know there is quite a variation but 1.2 volts seems excessive.
I have double checked everything else. The rails are fine. All connections are good.
I tried a 270K resistor from NI to ground but the offset went up to 4.6 volts!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 13th April 2005, 10:16 AM   #2
pinkmouse's Avatar
If the circuits are truely identical, then it must be the chip. Swap it out and see what happens.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 13th April 2005, 10:22 AM   #3
Nuuk's Avatar
But Al - I knew somebody was going to say that and all my lovely work will have to be redone!
Oh well, may as well get on with it then! Solder sucker where are you........
Old 13th April 2005, 10:50 AM   #4
shusha is offline shusha  Croatia
shusha's Avatar
Send a message via ICQ to shusha
What gain do you have without resistor from NI input to the ground?
Why not try some of those calculators: http://www.bcae1.com/opamp.htm
I find them very usefull. Can't memorise all of the equations (not using them on a daily basis).
Old 13th April 2005, 11:05 AM   #5
Nuuk's Avatar
Swap out completed but I am leaning ever so slightly toward PCB instead of P2P! (Is there an inverted 3886 PCB out there yet?)
So with the new chip, I get 37 mV. A pity that I can't remember where I bought that other 3886! On with the testing.......
Old 13th April 2005, 11:09 AM   #6
shusha's Avatar
Sorry, just saw it is inverted circuit.
Old 13th April 2005, 11:10 AM   #7
Nuuk's Avatar
The gain is set by the feedback resistor and input resitor as I understand it. This is an inverted circuit!
Old 13th April 2005, 11:12 AM   #8
Nuuk's Avatar
Sorry - just saw your second post!
Old 13th April 2005, 12:02 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
The offset can be caluulated rather easily and if you have rathe low-ohmish resistor values only the voltage offset will have inlfuence. In your case it's 1-10 mV times the DC gain => max 300 mV!
... and if the resistor values _not_ are low-ohmish _and_ you don't have matched resistor values for each input, then you will get additional offset. Why? Current flows into the inputs and they are not small in the context _and_ they are not equal, see the datasheet for input bias offset current.
Guess why I have only 18 kohms as feedback as compared to 270 kohms?
/Per-Anders (my first name) or P-A as my friends call me
Old 13th April 2005, 12:13 PM   #10
sek is offline sek  Germany
Yep.
But only DIY, I didn't want to spend the money for a 'professional' order.
It's a single-sided design on about 80mm x 32mm.
I guess you were talking about a board you can just buy and start soldering.
But anyway, just tell me if you are interested in pictures and details.
Sebastian.
PS: Forgot a little detail: it uses SMT resistors and caps for the low power components...
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
Using +/-70V on a LM 3886 Pery Chip Amps 17 23rd July 2007 09:58 PM
3886 problem (high DC offset) phresh Chip Amps 5 26th January 2007 02:54 PM
pre amp for 3886 bostonswoop Chip Amps 6 19th June 2006 02:58 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
Page generated in 0.12117 seconds (71.03% PHP - 28.97% MySQL) with 10 queries
