| Chip Amps Amplifiers based on integrated circuits |
#11 | |||
Nuuk said right. It depends on our taste ( & our system). My system is not hifi - just a set of typical things that make me enjoy the music
I am thinking of using 2W KIWAME carbon resister soon as it's mostly used in tube amp and claimsed that " Quote:
AFAIK, Kiwame is a prefer choiced by tube fans (seriously) as [they said] it''s very sweet & musical ( probably, it's not the same as what we call HI-FI Analog_sa - If you don't like the Kiwame res, I can help you keep it if you don't mind. |
#12 | |
Banned
I have a Krell on my bench right now. Not jokin', it's a Krell KAV-300IL integrated. It says "no user serviceable parts inside". |
#13 |
[QUOTE]Originally posted by nina
Panelhead - You threw it away just only when SEEING it has steel leads? These were cheap carbon films. Yageo if I remember right. I hoped they were penny each wonder resistors. Once they arrived, it was clear a penny each was all they were worth. The AB carbon comps I used are not that cheap. They are a dollar fifty for a 50 resistor pack at the local parts houses. Steel leads are bad for sonics. Avoid if at all possible. I buy most parts locally. Keep a magnet in the car to sort parts. A lot of the silver mica caps now have steel leads also. It all goes back to what people like. I used to remove old resistors and replace with Holco's fifteen years ago. Then spent years trying to find the crackles, pops, and other strange noises. One day I figured out that the Holcos were the problem. They did not like high voltages, and did not like having the leads bent. Now I would remove Holco's and replace them with Allen Bradleys. But I do not rebuild one equipment anymore, build it all new from scratch. George |
#14 | |
I was just thinking yesterday that I havent heard of anyone "skinning" resistors You know how some have a ceramic or paint coating, and you can crack it off to see the metal underneath? btw poster forgot C) dont care
| metal film or carbon film? | Roushon | Parts | 36 | 17th October 2011 10:33 PM |
| metal film resistors or carbon? | leitmo | Tubes / Valves | 2 | 28th June 2008 11:14 AM |
| riken resistors: carbon comp or carbon film? | jarthel | Parts | 0 | 20th October 2006 02:00 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 01:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 02:57 PM |
| Page generated in 0.09519 seconds (73.11% PHP - 26.89% MySQL) with 10 queries |
