| Chip Amps Amplifiers based on integrated circuits |
Friends,
I build an amp with LA 4663, and have - 197 mV offset on both channel. The schematic is taken from datasheet without any modification, only add a 10K potensiometer before input cap. What should I do to lowering the offset below 50 mV ? I have search the archieve, but no one using this chip. rgds, Gede |
#2 |
what kind of chip is this????Do u operate it with dual voltage supply???
#3 |
197 mV is simply nothing, don't worry about this offset.
#4 | ||
You can download it's d/s from www.alldatasheet.co.kr or from Sanyo website. It sounds good enough for my ears. The output stage looks like a balance amp but may be i'm wrong about this. Quote:
rgds, Gede |
#5 |
Looking at the datasheet, this chip runs into a BTL. Are you measuring the offset between output pins, or from one output to ground? Between outputs on one channel is the way you should be measuring it.
#6 | |
I measure between output ( Output + and Output - ) on one channel, not ground. If i measure to ground, it would be around 6,8 V with 15V supply, exactly as datasheet show. rgds, Gede |
#7 |
The spec sheet says the offset can be anything from -300mV to +300mV, so if you want lower offset you'll either have to change chip, or add a trim pot on the input to inject a small compensatory DC voltage.
Rune
Do wizards use spell checkers? |
#8 |
[QUOTE]Originally posted by runebivrin
[B] if you want lower offset you'll either have to change chip, or add a trim pot on the input to inject a small compensatory DC voltage. Hi Rune, Do you mean add a trimpot after the input caps in series to the input pin or to Ground ? I won't change the chip because I want to learn more on how to solve offset problem with chip amp Gede |
| Page generated in 0.10618 seconds (80.84% PHP - 19.16% MySQL) with 9 queries |
