| Chip Amps Amplifiers based on integrated circuits |
Sorry, I know there are a million ground loop help posts on this forum, did my best to trouble-shoot and search but I have run out of ideas and need a little help…
I have constructed the stereo version of Brian’s LM3886 kit boards and am getting some ground loop hum. I am using one of the new snubberised power supply boards to power two amps. I have wired as directed. The problem I am having is that the amps are dead quiet when there is no input connected or when only one input is connected, but when two inputs are connected I get loud hum. The trouble shooting I have done: Both input RCAs are insulated from the chassis. Input cable from RCA to amp board is dual core shielded with the shield tied to ground at the RCA end only. Chassis is grounded to earth wire of input 240VAC. Hum is the same with CHGND connected to chassis or not. I can induce the same hum by linking a single RCA cable between the two input RCA jacks (with or without chassis ground on pcb connected). I suspect that the ground loop is happening when the two signal grounds on the amp boards are joined at the signal source and that the othe side of the loop must be through the power supply board. Am I on the right track? Can anyone offer any suggestions? Thanks for your help guys, Chris |
#2 |
That kind of hum behavior you have , points to a problem with the rectifierboard.
Steen. |
#3 | |
Banned
The problem is that there is probably a long distance between the two channel's power ground and the PSU gound. What I mean by this is that the two boards with the chips must be close to each other so that the ground wires are as short as possible. Brian has sent me some boards for me to try (thanks Brian) and I'm building an amp with them. Should be finished, but I have been busy... It's almost done, but I think you can get the picture. The solid copper wire joins the power grounds of the two boards. The center point of this solid copper wire connects to the PSU ground. The ground arrangement on the PCB is not the ideal, because the power ground point should be only one, in a star arrangement. I am joining PG+ and PG- with a wire. |
#4 |
Thank you Carlos,
Yes the boards are about 6 cm apart. I will try your suggested grounding scheme. Away with work for a few days tomorrow, will try to re-wire this afternoon and post back before I go. Once again, thanks for the help! Chris |
#5 |
Carlos,
i think im missing something here, but i dont see how your power ground arrangement is different from using the CHG pads? How is the CHG pad different from the center of your copper wire joing the PG+ and PG-? The way i see it, they are connected to the same things... Also, why is keeping ground wire short so important? EDIT: and where will you connect power ground wires from rectifier now?
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#6 | |
The most important part is the heavy wire between the two channels. These boards each have a local star, which is fine, but then each board has two returns to the PSU board which is not ideal - especially if the PSU board supplies two channels. I presume Carlos will connect PG+ and PG- from the PSU board to the center of the wire joining the two channels. This will form a central star at this point which branches to the local stars on each circuit board. My P2P amp was dead silent - the two amps I've built with these boards have a very slight hum. It isn't at all noticeable unless you put your ear to the woofer, but it is there. If one is not careful about the wiring (match the lengths of all the ground wires and keep them short) I think it turns into a bigger problem. |
#7 |
I am using one transformer (dual secondaries) but TWO rectifier bridges in my next project. I am using brian's LM3875 Rev.3 boards.
How should these be optimally grounded/wired?
#8 |
Ah, now you have me thinking... I was going to attack this problem tonight, but after reading Carlos' suggested wiring, I had assumed that by "The center point of this solid copper wire connects to the PSU ground" he meant that I should tie the PG+ and PG- at the PSU to make one ground, and to use one wire to connect that to the centre of the power ground joining the two amp boards. Jeff talks of using the PG+ and PG- (two wires) and joining them to that same point. Does it make a difference?
Thanks again everyone for the input. Hope to have this sorted out tonight before I go away. Cheers, Chris |
#9 | |
I've noticed that some people twist their power/ground cables together. Is there some benefit to this or is it an asthetics issue? regards Dave |
#10 | |
| Brian's Kits | thermonuclear | Chip Amps | 2 | 17th November 2005 06:58 PM |
| problems with Brian's kits | thermonuclear | Chip Amps | 19 | 10th November 2005 02:53 PM |
| PS for Brian's chipamp 3886 and 4780 | rgrayton | Chip Amps | 0 | 20th April 2005 11:39 PM |
| Where can I get Brian's LM3886 GainKlone PCB or KIts ? | aherb | Chip Amps | 1 | 31st March 2005 12:04 PM |
| Page generated in 0.14795 seconds (68.91% PHP - 31.09% MySQL) with 11 queries |
