| Chip Amps Amplifiers based on integrated circuits |
Hi All!
I found the following circuit at http://home.s-planet.de/t.dauner/7293/ It is quite similar to the one which was published in UB electronics some time back. Can someone explain the function of the caps/resistor network between Pin 2 & 14. The recommended circuit has only 1 resistor between those pins. Thanks! |
#2 |
100u caps are there to set DC gain to 1
R103 - feedback resistor C3 prevents oscillation C1 bypasses 100u caps R1 - don't know for sure R102 - gain setting resistor
Nothing is as simple as it seems |
#3 |
It is a filter. It cuts away frequencies out of the audio band ( 20 Hz - 20 kHz).
Best regards Bo |
| PCB for TDA7293 | jbdivx | Chip Amps | 8 | 7th October 2010 02:45 PM |
| need help with TDA7293 | weatherlight | Chip Amps | 19 | 20th June 2008 12:55 PM |
| TDA7293 Max PO without high-n circuit? | Bosium | Car Audio | 2 | 19th September 2005 10:39 AM |
| tda7293 circuit | Al Bundy | Chip Amps | 4 | 4th July 2004 11:10 AM |
| Where can I get a TDA7293??? | mfish0305 | Solid State | 2 | 18th January 2004 03:19 AM |
| Page generated in 0.08135 seconds (73.07% PHP - 26.93% MySQL) with 11 queries |
