Old 6th April 2005, 05:02 AM   #1
Default LM3886 Distortion Sources
My gainclone experience has hit a turn for the worst recently.
I destroyed one channel of my amp by shorting the pins of the chip to metal plate that was holding it to the heat sink. Oh well, you live and learn I suppose. I am going to order some replacement parts and repair it.
At first I figured I would just use the amp in mono for now, but having plugged it in, I realized that I probably shouldn't use it at all until I resolve some distortion issues I'd been having. (They haven't appeared after my destruction of the other channel, they've always been there) For some reason, I get significant levels of distortion (not clearly audible to my friends), but definitely pronounced enough for me to detect it, and seems to have caused one of my tweeters to start popping. I don't want to scrap this amp, rather I would like to fix it. What are the various sources of distortion I should check for?
Old 6th April 2005, 06:09 AM   #2
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
If the distortion is constant it might be your rectifier diodes, another member of this forum had the same problem first he thought that it was because his toroid were to close to the PCB's but it turned out that it was his MUR860's he changed them and the noise has gone away.
You could try to measure the DC outputs on the rectifier board in a minut to see if the voltage is stabil.
Frandsen
Sources of distortion in ribbon loudspeakers thadman Multi-Way 1 1st July 2009 07:38 PM
Distortion in stereo LM3886 amp umut1001 Chip Amps 2 21st August 2007 07:03 PM
Page generated in 0.07886 seconds (59.73% PHP - 40.27% MySQL) with 10 queries
