Old 6th April 2005, 06:29 AM   #1
bochek is offline bochek  Canada
Default diy amp help, new to it
just doing a bit of recherche, and i would like to make a amp using the lm3886 chip, i need it to put 65 wats into each speaker, 4 speakers in total, each speker is 4 ohms, if anyone has a simple schematic it would be greatly apprecieated
thanks,
adam
Old 6th April 2005, 07:25 AM   #2
dab is offline dab  United States
Default Check spec sheet
You could use the spec sheet schematic. Times it by four and add a 30volt supply. It is about as safe as it gets or check out some of kits available.
http://cache.national.com/ds/LM/LM3886.pdf
Dwayne
make hifi not bombs
Page generated in 0.06020 seconds (62.21% PHP - 37.79% MySQL) with 9 queries
