| Chip Amps Amplifiers based on integrated circuits |
I am planning to build Monte Kay's RS Dipoles (http://www.mfk-projects.com/rs_dipole.htm) and I am trying to sort out amplification. The two midrange drivers are connected in parallel as monte has it. I have already ordered 4 x brian's lm3886 stereo kits. I am going to try the speakers with 1 channel for each tweeter, 1 channel for the pair of midrange's, and 1 channel for each 10" woofer. The output for each channel will come from the behringer DCX2496, so my question is, how do i connect up the outputs of the DCX to the amps so that i can power each woofer with it's own channel of amplification but from the same output as the other woofer on that channel?? If it turns out that the amps are not powerful enough (i am not really sure) I will buy a cheap pro-amp (alesis RA500 most likely) for the woofers, and use 1 channel of lm3886 power for each of the midranges, so would i connect them in the same fashion? This would probably be ideal as it would present a very easy load to each of the chipamps. Thanks for your help, Pete W |
| 2 Woofers in Parallel Config - 4 Options | HiFiNutNut | Multi-Way | 16 | 23rd November 2006 03:23 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? | Cal Weldon | Multi-Way | 16 | 21st February 2004 12:31 AM |
| unidentical woofers in series/parallel? | Jay | Multi-Way | 5 | 25th January 2004 09:18 PM |
| xover with woofers in parallel + tweeter | trespasser_guy | Multi-Way | 6 | 5th January 2003 02:12 PM |
| Page generated in 0.07360 seconds (67.67% PHP - 32.33% MySQL) with 10 queries |
