| Chip Amps Amplifiers based on integrated circuits |
#61 | |
I did some quick experiment on LM3875 (24Vdc) using the value of R1 R2 R3 as 22K, 301 and 10K respectively. I am afarid the difference is not noticable in my system but the DC offset is very high ~600-900 mV. Is there something wrong with using these value of res? |
#62 | |
Banned
Input coupling cap? A volume pot? An active preamp? A buffer? If you respect the values of my schematic and only increase the value of R3 (feedback), if you need more gain, it should be ok. |
#63 | |
How does it sounds ? I saw the picture of the inside of your amp. Do you have the PSU outside the amp ? ( I will put my PSU outside ) Carlos, can you tell me where to buy a nice and cheap 10k pot ? Thanks.
If you want power you must add control |
#64 | |||
Banned
Powerful. After the mods, a very good integrated. Before? Quote:
Regulated, snubberized. Quote:
Get these Alpha pots from Jaycar UK: http://www1.jaycarelectronics.co.uk/...Max=&SUBCATID= |
#65 | |
I have to order at least £20 in components
But I was needing some new parts BTW, thanks for the link, I didn't know this online shop ![]() Quote:
#66 | |
Banned
#67 |
Carlos, have you ever tried to annul the DC OFFSET and take the capacitor C1(2.2uF) out of the LM3886 input?
#68 | |
Banned
To null DC-offset to 0mv on the NI amp you can insert a cap between R2 and ground. But as I use (and recommend) very low value resistors, that cap would have to be big and it would have impact in the sound. For 100R (R2) the cap would have to be 470uf. |
#69 |
To null the DC-offset of my "pre" SE to differential converter, I used this technique :
(the psu will be regulated(12V)) The problem is that I have to tune the pot.... with some regularity ![]() I think this way I will not need the cap C1 in the amplifier input But I still have to test it... don't know if will work Edit: I don't know if the symbol of the pot is correct
#70 | ||
Banned
But you must have a well regulated PSU. At least double regulation for that voltage. Quote:
Gives me free of mind to connect anything to my system. Some sources have (not negligible) DC-offset. In your case that trimmer drifts, and DC-offset on the output of your pre will be amplified by the gain of the power amp (20~22x). A source component that hits 10mv DC-offset on the outputs (even if it's only with music playin') will give you 200~220mv DC on the output of the amp. |
| what capacitor type is best used on Carlosfm's non-inverting chipamp? | jarthel | Chip Amps | 8 | 24th August 2007 12:12 AM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 06:53 PM |
| Page generated in 0.12393 seconds (81.60% PHP - 18.40% MySQL) with 11 queries |
