| Chip Amps Amplifiers based on integrated circuits |
#41 | |
It doesn't much matter what is used here in my set-up because the driving source impedance is always much lower (a few hundred ohms.) |
#42 |
Banned
And how does it sound?
#43 | |
![]() Compared to the "standard" gainclone values (22K and 680ohm) I noticed a shift away from the HF, which I always thought was a little exaggerated before. I also noticed some separation and textures that I'd not heard before - and this was on music with which I'm quite familiar. ![]() This was with only a couple of hours on the amp. It's certainly worth trying! I think I'm going to prefer it in the long run. |
#44 |
Banned
Thanks, I just had to ask, because I thought I was dreaming.
Let it PS: notice the wall-to-wall soundstage. |
#45 |
FYI - R3 in Carlos' schematic should be at least 1/4W and 1/2W rating would be preferred. 1/8W would be exceeded at full power.
#46 |
Banned
Btw I use 0.6w 1% film resistors, from Philips.
#47 | |
![]() I just wanted to point this out to others who might build. I saw some people using 1/8W resistors in their photos of other projects. I used a .6W Beyschlag metal film. It's the perfect size to fit between the pins on the underside of the board. Listening some more this morning, I remain very impressed. Good work! |
#48 |
Banned
With the second snubber near the chip, there are advantages in using bigger caps than 100uf.
I started testing with 470uf and yes, extreme bass gets tighter. Then I tested 2,200uf and... This is it! Midband and treble are gorgeous, as ever, but the bass is really on another league. PS: If you are wondering, I do not test amps with choral music. There's a good recording from the beginning of the 90's (!) that always was a good test: Counting Crows - "August and everything after". Believe me, very few amps can drive my Epos speakers with this disc. This one does it: |
#49 |
Banned
The PSU is, of course, the high-cap. snubberized.
3x4,700uf per rail, MBR16100 diodes, heatsinked. The amp, with the new caps: |
#50 |
Banned
No, I'm not joking.
I have this at home. |
| what capacitor type is best used on Carlosfm's non-inverting chipamp? | jarthel | Chip Amps | 8 | 24th August 2007 01:12 AM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 07:53 PM |
| Page generated in 0.12100 seconds (75.10% PHP - 24.90% MySQL) with 11 queries |
