| Chip Amps Amplifiers based on integrated circuits |
#21 |
Last night I tried replacing the 0.2 Ohm res with L||R network in ser. with the output. The res is 10 ohms/1W and I put 8 turns of wire (24AWG from a network cable) on top of it. My GC is even more civilized now. So I do recommend using it. It protects from instability in the HF range much better that the 0.2 res no matter the type of speakers. Also it allows me to go higher with the FB resistors for better DC offset (I'm using 4.7k/100k) without ill effects.
So I recommend using the L||R with high cap PSU. Just my observation. Greg |
#22 | |
#23 | |
Banned
Do you know the internal contruction of the wirewound resistors? How do you cancel the inductance externaly? Winding in the opposite direction? Here we go again, discussing the resistors' polarity. |
#24 |
To Carlos : Not neccessary, look at Caddock resistors, typ MV 234.
#25 | |
Hi Carlos
I have only used conventional insulated copper (wire wrap or magnet wire) bifiliar wound and the ends connected in reverse phase. Of course you get only half the resistance this way. It seems like a more economical solution to follow Sully's suggestion from the quoted thread. As i intend rebuilding my GC with 3886 following all your recommendations i guess it's winding time again
#26 | |
Banned
I never considered building my own resistors. "If you want to make an apple pie from scratch,you must first create the universe." (c) Carl Sagan
#27 | |
Tom probably spends longer but he is really a perfectionist. |
#28 | |
there was an item in the Linear Tech magazine (I think, correct me if I am wrong) on calculating R for current shunts by designing them on the PCB. what are you using for resistance wire. and another completely irrelevant sidebar discussion on resistance wire -- the reason that "toasters" in the U.S. in the 1950's lasted so long was that GE and Westinghouse bought up large stocks of government surplus nichrome wire -- the kind which was used in flying suits (and tested to a high standard) -- you couldn't kill one of these things -- us cynics believe that in order to get the market for small appliances moving they substituted inferior wire as part of programmed obsolescence. my mother uses the same toaster she received as a wedding present in 1949. |
#29 |
Programmed obsolescence is very real and accelerating. We got a basic steam iron about 10years ago. It lasted about 7years. Since then we have had to replace one every year.
Every time I go into my local repair shop I see huge flat screen TVs piling up, with about one or two years on the clock. Our ex rental TV is still going strong after 10years. Quite frankly it disgusts me. Shoog |
#30 |
I was told by somebody in the trade that washing machines are designed to last just two years.
Given the amount of energy involved in making these items, and then diposing of them and then recyling the parts, this is nothing short of environmental suicide!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
| what capacitor type is best used on Carlosfm's non-inverting chipamp? | jarthel | Chip Amps | 8 | 24th August 2007 01:12 AM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 07:53 PM |
| Page generated in 0.14445 seconds (80.82% PHP - 19.18% MySQL) with 11 queries |
