Old 17th January 2006, 08:18 PM   #241
juma is offline juma  Serbia
juma's Avatar
Carlos,
that's what I planned, anyway. I just thought that you might have something up the sleeve considering the time and effort you invested in snubber applications.
As for UNO, I don't presume it can beat your AD815 pre (I built it and I enjoy it, thank you once again). It's just that UNO is so sweet and simple that I might give it a try.
Cheers !
Old 17th January 2006, 11:42 PM   #242
Banned
Originally posted by juma
Carlos,
Cheers !
That's right, the UNO is just too good for what it is, that's it.
Build it, I would like to know your oppinion.
It has a snubber.
Old 30th January 2006, 12:07 PM   #243
juma's Avatar
Default LT1083
For the last ten days I've been trying to implement LT1083 as regulator for Carlos' NIGC, actually to find snubber values that would make it sound at least as good as unreg. snubbered, but without succes. It just doesn't seem possible to get that GC midband magic out of LT1083.
33nf in parallel with 0R33+33uF on the output of LT1083 are the best shot, but mids (especially voices and strings still sound like performers stepped 1 meter back from the microphone). At the same time bass started to get bigger volume and deeper blow with same control it had previously, which happened no matter what snubber combination I used.
It looks like that LT1083 would have done well in bi-/tri-amping system (PSU for bass amp).
I'll keep on trying (shame to waste such expensive devices), but not many tricks are left in the box.
Cheers
Old 31st January 2006, 09:43 AM   #244
juma's Avatar
Default LT1083 - problem solved
Well, as it happens sometimes in life, I was looking for for solution on the wrong place. There is nothing wrong with LT1083 (au contraire). The problem was in coupling cap between AD815 preamp and power amp (3,3 uF Siemens, industrial type MKT).
Having no Black Gates on hand (and not being ready to pay 40 EURO for a single 3,3uF cap, even if it's made from fairy dust and unicorn's tears), I decided that no cap is best cap and went for direct coupling.
Since AD815 has 30mv DC offset on its output it is obvious that LM3886 should have unity gain for DC, so Ci came back in play as 220uF//4,7uF Wima//100nF MKP in series with 200 Ohm as Ri and 4K3 as Rf.
And yes, Ci made this way affects the overall sound much, much less than it does usually (coupling cap in direct signal path does a lot more damage, magical or not).
And now, sound is right, everything is as it should be, all benefits of standard Carlos' circuit are present, plus benefits in bass that I mentioned in previous post (and improvements descended from using a regulated PSU in this integrated amp).
One thing should be kept in mind: the source component (CD/DVD player, DAC, PC sound card, whatever) should have no significant DC offset voltage on its output (up to 20 mV is OK) in order to keep it under 100mV on the speaker.
Attached is schematic and picture of amp (built p2p of course).
Cheers
Old 31st January 2006, 07:24 PM   #245
Banned
Another satisfied customer.
Old 1st February 2006, 09:33 AM   #246
juma's Avatar
I suppose the satisfaction is mutual, since you've been sharing freely results of yous efforts (I don't remember Carlos tried to sell anything on this forum). And the end result is as it should be: more people are building good amps and listening to the music in a more joyful manner.
Thanks Carlos !
And here is a web page that I stumbled upon (let's share some laughs too). I don't remember when was the last time I laughed so much - be careful, this can lead to serious injuries :
http://www.dself.dsl.pipex.com/ampin...j/failproj.htm
Cheers
Old 18th April 2006, 01:23 AM   #247
Finished the board for the non-verting power amp today. I listened for about five minutes,it sounds OK. I will burn it in for 3 days and give it another listen.
It is a little different from Carlos' schematic. I didnt have all the parts for the snubbers.so the values are different. I used .33ohm and a 1nf cap instead of .1ohm resistor and 3.3nf cap. The power supply snubber components are the same as schematic's
I also used a 4.7uf cap bypass with a polystylene,I dont know if it help but I brought 150pcs,so I will use them someplace.
Old 18th April 2006, 01:25 AM   #248
Here is a slightly different angle
what capacitor type is best used on Carlosfm's non-inverting chipamp? jarthel Chip Amps 8 24th August 2007 01:12 AM
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 07:53 PM
Page generated in 0.10598 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
