Old 2nd April 2005, 09:24 PM   #1
Anthrax is offline Anthrax  Australia
Send a message via MSN to Anthrax
Default Need help with LM3875 as bass amp
i've done a seach, and read through the pages about the "simple guitar amp" using a gainclone.
but i'm thinking of making a simple bass amp for practise.
using this schematic
http://circuitos.tripod.cl/schem/r78.gif
and then having a bass preamp go before it, with the bass guitar going into the preamp. would this work ? will there be any changes to be made in the power amp section to accomodate for the more bassy'er input ?
any help would be awesome.
also, what voltages should those caps be ?
Old 2nd April 2005, 09:33 PM   #2
As bassguitar amp it will be quite OK, you can't change values of devices. You must use caps for 35 V DC.
Old 3rd April 2005, 11:32 AM   #3
thanks for the reply. i have one last question.
can anyone suggest a good PSU for that particular design ?
Old 3rd April 2005, 01:44 PM   #4
edl is offline edl  Hungary
edl's Avatar
let's see the NFB.
the RC's are: 1Kohm and 10uF. this gives 16Hz...
for bass guitar, it won't be good! the freq response will starts at 30-40Hz!
let's use a 47, 100, or even a 220uF capacitor there!
LM3875 Kit Finished - Could use some more bass johan851 Chip Amps 91 31st March 2008 01:13 PM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
LM3875 bass amp oris horns Diy martin Chip Amps 0 4th November 2006 07:18 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.07881 seconds (75.77% PHP - 24.23% MySQL) with 10 queries
