My "audiophile" LM3886 approach - Page 404 - diyAudio
Old 21st August 2012, 05:04 PM   #4031
bcmbob is offline bcmbob  United States
O.T. Got a reply from Uriah and he is feeling much better and is making good progress in his situation. Let's keep him in our thoughts and prayers.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st August 2012, 05:17 PM   #4032
dudaindc's Avatar
Thanks Bob!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 22nd August 2012, 05:32 PM   #4033
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Originally Posted by PreSapian View Post
... and it had definitely made the sound less musical. i only figured this out after an extended listen. koa 1k ohms are back in and caddock 1k will be ordered :P
wrong move, I guess...
In this case I bet that what made it sound "less musical" is not the (not so much) different value of the resistors, but rather their different construction technology. Carbon resistors usually tends to give a "warmer", "richer", "more musical" touch to the sound, while on the contrary metal film ones tends to give a "dryer", "cleaner" and "colder" one.
For this reason, to get a more "balanced" sound Thorsten suggests to use carbon resistors on solid state gears and metal film on tubes ones.
Thus in this circuit I'd suggest trying to use carbon compound resistors such as Kiwame or similar just about everywhere it's possible.
In general, use the highest wattage resistors that you can fit on the PCB: that will reduce transient thermal effects (distortions). This is particularly important on the NFB network(s), where these (and other) subtle effects gets hugely amplified by the loop gain.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 22nd August 2012, 05:44 PM   #4034
hi unixman,
thanks for the advice but they were both carbon film resistors. caddock 925 the value definitely affects the sonics. as linuxguru says, lower value= lower distortion. but since his lf01 modules that im using is already pretty much 2h dominant, well you can see how that goes.
eric
Old 23rd August 2012, 04:34 AM   #4035
oops i forgot, the 1k was kiwami carb
Old 27th August 2012, 08:06 PM   #4036
UnixMan's Avatar
well, of course it does...
Old 28th August 2012, 05:52 AM   #4037
hey
unixman
im sorry. 1k was carbon film resistors. (im starting to lose track of them after too many swaps) thick film caddock definitely had more refinement. notes bloomed more
noticeably also, and there was less grain. this i think i can blame on material composition,
because those are the general traits of thick film resistors. no doubt 1k caddock would be the best choice for me.
Old 28th August 2012, 05:55 AM   #4038
atupi is offline atupi  Romania
Try to retrofit Dario's shunt's. Way better than resistor-zenner.
Old 28th August 2012, 10:44 AM   #4039
ive tried it and still prefer 1k resistors. they sound more intimate
Old 18th September 2012, 12:06 PM   #4040
thank you
It looks very good
Copyright 1999-2017 diyAudio
