My "audiophile" LM3886 approach - Page 402 - diyAudio
Old 27th May 2012, 10:49 AM   #4011
A new cap is effectively one that has been freshly reformed. This applies irrespective of whether it was manufactured yesterday, or last week, or last month, or a year ago. If it has been on the shelf and/or in transit for longer than 24hrs, then it must be reformed immediately before testing/measuring.
Once you compare a freshly reformed "in spec" cap to a 100hrs in operating mode also "in spec" you should find that there is no difference.
If you pick an "off the shelf" cap that is leaking "out of spec" because the insulation has degraded, then it almost certainly will be different. It is "out of spec" and by definition it is different.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th May 2012, 11:41 AM   #4012
soongsc is offline soongsc  Taiwan
soongsc's Avatar
And freshly reformed X and Y caps will not change after 100hrs of operation?
Hear the real thing!
Old 27th May 2012, 12:42 PM   #4013
I am referring to the electrolytics that must be reformed.
Example : effective resistance at the 100uF's+supply of 0.1R, some 50nH inductance from wiring,
regards Andrew T.
Old 27th May 2012, 01:00 PM   #4014
soongsc's Avatar
Did a search on this subject, very interesting. So it seems like a bad idea to switch any equipment off because probably all circuits have electrolytics somewhere.
I am also interested whether this applies to the newer solid state electrolytic devices or not?
Old 27th May 2012, 02:23 PM   #4015
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by soongsc View Post
Do you see much variation between a new cap versus after 100hrs or more run in?
No, as the series inductance (ESL) of any cap is only dependent on its geometry, caps from the same maker which have the same dimension (can size and lead spacing) have identical ESL. ESR is mostly dependant on temperature, though.
Old 28th May 2012, 11:52 PM   #4016
Speedskater's Avatar
An old thread about X and Y caps.
X2, AC Line Capacitors
Kevin
Old 29th May 2012, 03:03 AM   #4017
soongsc's Avatar
Thanks Kevin. I notice change in sound after 100hrs of operation, but the change is really small. This caps are often used to prevent noise from coupling into the mains power line and making an antenna out of those lines. Interesting to see people reporting change in value to the tolerance limits in as little as 1000hrs.
Old 29th May 2012, 10:02 AM   #4018
.............Interesting to see people reporting change in value to the tolerance limits...........
Where?
In the X2 link?
regards Andrew T.
Old 29th May 2012, 11:53 AM   #4019
soongsc's Avatar
Yes. In the linked thread that Kevin provided mentioned 10% in 1000hrs.
Old 29th May 2012, 12:05 PM   #4020
X & Y capacitors are self healing. That is one of the basic characteristics that allow them to be used on the Primary side.
As a result of self healing any transient that "burns out" a section of the capacitor must become a non capacitor area.
Each overloading transient will reduce the area of the capacitor's plates.
It is a natural consequence of overloading a self healing X or Y capacitor that the capacitance will reduce.
The worse and/or more frequent the overloading the quicker that the X or Y cap will lose capacitance.
If you read the X, Y cap info you will find all that information either directly or by inference.
Learn to read.
regards Andrew T.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
