My "audiophile" LM3886 approach - Page 390 - diyAudio
Old 11th May 2012, 09:56 PM   #3891
oh sorry. there's a part where he compares sonics of bunch of bjts and 639 is one of them.
edit: i just found out that my speaker ports were blocked off for the better part of the listening session all day... how embarassing (long story why i plugged them up)
Old 11th May 2012, 10:19 PM   #3892
Reality first!
ClaveFremen's Avatar
But it don't rates badly the BC639...
And you must take in account that each manifacturer has its distinct sound signature, the best sounding are OnSemi and NXP, fuller and more balanced than Fairchild, ST are way worse.
And finally his findings are about using those transistors as buffers, not exactly the same application...
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 15th May 2012, 09:47 AM   #3893
Send a message via Yahoo to linuxguru
A pic of the first MyRef_X2 aka Evo2 prototype, almost fully populated (just missing the LM318/LF01 and a few passives) - the large metallic cylindrical component at front right is a 1uF Russian K71-5 Polystyrene. The rest of the stuff is more or less the Rev C BoM, with some uprated/larger-valued components and minor compensation changes. Just one monoblock so far - I hope to complete it as well as another identical monoblock for power-up by the weekend.
Old 15th May 2012, 10:37 AM   #3894
atupi is offline atupi  Romania
Looking wonderful ! Let's see how it sound ...
Old 15th May 2012, 10:43 AM   #3895
Reality first!
Well done
We'll wait for your comments.
Those caps are very good ones, I tried the axial version with great results.
Dario
Old 18th May 2012, 05:53 AM   #3896
could you tell me which pin that gets bypassed by c7 has the lower impedance? ill be connecting vcap cutf to that location and it talks about outer/inner foil here V-Cap Audio Capacitor Installation Notes
i must say, the caps are rather extreme but i'm still in the firm belief that c7 adfects the sound as much as c13.
and longer lead length or not, i have found full sized axial caps to sound uncomparably better than thruhole caps for this location
Old 18th May 2012, 07:42 AM   #3897
C7 is a +12V to -12V rail-to-rail bypass for the LM318. It bypasses Pin 7 (+Vcc) to pin 4 (-Vcc). If you mean impedance to ground, it's hard to say which has the lower impedance, but in any event it's shunted by the dynamic impedance of the zener, which is in the tens of ohms, and much lower than the dynamic impedance to ground looking into any power pin of the LM318.
I'd advise against using any long-lead axial at that location. Any film/foil type with short leads does fine there - either FKP2, FKS2, FKC2, KC1850, KP1834/35 or similar.
For the LF01, choices are a bit restricted because of the 2.5mm lead pitch, but most of the above can be squeezed in by bending the leads inwards.
Old 18th May 2012, 08:27 AM   #3898
Reality first!
Connect the outer foil to V-
I must say, the caps are rather extreme but i'm still in the firm belief that c7 adfects the sound as much as c13.
As I've told several times, while you're right about C7 importance and impact on sound, you can't ignore the cap primary goal: DECOUPLING
So:
Dario
Old 18th May 2012, 12:06 PM   #3899
bypass is different from decoupling.
The two terms are not interchangeable.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th May 2012, 12:30 PM   #3900
Reality first!
Hi Andrew,
I've thought that they were interchangeable but after a brief google search I understand that this is not so but the difference is not completely clear to me.
Can you define the exact difference,please?
Thanks in advance
Dario
Copyright 1999-2017 diyAudio
