| Chip Amps Amplifiers based on integrated circuits |
| Thread Tools | Search this Thread |
#3681 |
They're Kemet/Arcotronics R46
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#3682 |
Hi. Today i used 2n5484 FETs to bias LME49720 in class A in my AK4396 dac, and i must say it sounds wonderful. Has anyone tried biasing LM318 in MyRef?
Is there any reason not to do it? |
#3683 | |
My audible impressions : Smoother, more airy, less edgy than the stock LM318. No significant regression has been observed yet, but similar audible improvements can probably be obtained from Dario's shunt-regulator upgrades alone. Maybe the shunt-regulator upgrades + LF01 will be even better, but that's still on the to-do list. I've been distracted for the last few weeks running simulations on a discrete opamp designs, so I didn't get around to doing the shunt-regulator upgrades or anything else related to the MyRef. |
#3684 |
Slightly OT - what's the bias current, and is it sourcing out of or sinking into the output of the LME49720? FWIW, I found the stock LME49720 a bit disappointing as an I/V converter in comparison to its specs. OTOH, the stock LT1361 sounds very good indeed, even better than the LT1364 and the dark and detailed OPA1612A. It's possible that some of these will sound better in Class-A operation.
#3685 | |
You should try ASAP... ![]() I'm enjoyoing the Fremen Edition beta now, it sound gorgeous You should try OPA827, it's an incredible subjective performer on I/V.
#3686 | |
I used the lone FET method described in tangentsoft. Biasing Op-Amps into Class A I have to agree with you about LME49720. Although it sounds wonderful biased in class A i still prefered stock AD8066 in that position. AD8066 was much better in terms of resolution and seperation of instruments, plus it had a huge soundstage. I didnt try biasing AD8066 in class A because all of a sudden it stopped outputing in one of the channels |
#3687 | |
I'll try to get hold of a few OPA827s and give it a try - they're single opamps, so I'll have to mount it on a dual SOIC8 to single DIP8 adapter like the Sjostrom type C or similar (the Marantz CD4000 uses a DIP8 dual opamp for the I/V converter). |
#3688 |
![]() Siva, can you give me an opinion on post #8's grounding problem? Also my SACD player uses dual opamps for I/V, I've mounted OPA827s on browndog adapter with GREAT results.
#3689 |
Kindly excuse this basic question
And whether it works in current-feedback as shown on this page - Lenard Audio - Education - Amplifiers. So that the impedance variation of speaker with frequency variation of sound will taken care with variable gain of amplifier. If its true, it means awesome sound
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
#3690 | |
However, it is not a current feedback topology - the GNFB loop is still a conventional voltage-series feedback loop from the load. Nevertheless, the topology and compensation schema are novel and unique, giving it outstanding sonics even with a commodity opamp and chipamp. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.13792 seconds (64.14% PHP - 35.86% MySQL) with 11 queries |
