My "audiophile" LM3886 approach - Page 364 - diyAudio
Old 31st January 2012, 01:11 PM   #3631
Reality first!
ClaveFremen's Avatar
First of all thanks for the interesting post
So, If I understand correctly, the only method you consider safe is connecting PNGD to safety ground via ESP ground breaker or at least a diode bridge (as parallel diodes).
I suppose that also PGND to safety ground is safe but not advisable for ground loops and/or noise injection problems, right?
Originally Posted by AndrewT View Post
All of this has been posted by many Members on this Forum.
Probably I've missed it, BTW most of Nelson Pass' PS uses thermistors as the only path for fault current.
I've read somewhere also about the single power resistor as an effective method.
Maybe my informations are not complete or right and I appreciate your suggestions.
I appreciate less this sentence...
It is completely irresponsible to give dangerous advice simply because you have not informed yourself.
I've simply trusted mr. Pass:
The power supplies of each channel are isolated from each other
electrically, except for a thermistor on each which connects the circuit
ground to the chassis and earth ground. In this way ground loops are
prevented, as the channels will typically share ground only at the source,
but the thermistors stand by to conduct AC line voltage to ground until the
fuse blows, in case of transformer or other such failure.
(from F1 service manual)
And many others, BTW.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 31st January 2012, 01:18 PM   #3632
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
One fault should never kill anybody.
just make sure that whatever you put between the signal ground and PE can safely withstand at least more current than the local fuse(s) will allow.
Of course the case and PT (core and screen if present) must be always directly connected to PE. As should be any other metal part which can be earthed without problems.
To avoid ground loops, signal input/output connectors must be kept isolated from the case.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 31st January 2012, 01:31 PM   #3633
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Based on my experience, when too large capacitance is used where Y caps should be used, the leakage current will create small shock. This tells me that protective grounding does not work as expected. This had been verified in a qualified lab with earth ground according to requirements. However, since the regulation requires it, a commercial product should adhere to it. Class II appliances do not have connection to earth ground, thus have a different set of insulation requirements.
Dario, in my switching power, loading it with too much capacitance will trigger the protective circuit.
Hear the real thing!
Old 31st January 2012, 01:32 PM   #3634
GloBug is offline GloBug  Canada
Banned
Originally Posted by UnixMan View Post
the safety scheme works by triggering the differential breaker (AKA Residual-current device): any unbalance current (that is any current not flowing back through neutral but flows through earth instead) above the safety device set point (max 30mA here in Italy) will trigger the breaker and cut the mains. Hopefully BEFORE anyone will come in contact with the failing appliance.
Although from a normative point of view things may be different, from a technical (and safety) point of view there are no problem whatsoever as far as you don't break (or substantially limit) the AC&DC conduction from circuit ground to PE in presence of dangerous voltages between the two.
Thus from a technical (and safety) point of view there are absolutely no problem if you insert a small valued resistor/thermistor, anti-series zener diodes, inductor, etc between signal ground and PE to open ground loops or limit their nasty effects.
Perhaps you may not get CE certification that way, but that's another story.
If your referring to what most would call a "GFCI", they are for "extra" protection in certain situations, I would certainly not rely on them, simply because they are not reliable.
Add to this a GFCI won't protect you from stored voltage in your device amplifier should it have such a fault.
Old 31st January 2012, 01:37 PM   #3635
I had used a low value resistor between Signal Return and Main Audio Ground.
That is until a Member posted a schematic in which I noticed he had a diode across that resistor.
That got me thinking about the exposed RCA barrel at the other end of an interconnect.
I now use inverse parallel diodes (1n400x) across all my low value resistors that may have to pass some fault current, irrespective of which end of the interconnect cable has the fault.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st January 2012, 01:53 PM   #3636
Reality first!
I don't understand... what are you referring to?
In the My_Ref there's no single place where a Y cap should be used apart the connection between IEC/fuse/transformer primaries...
Ok, so you were referring to the switching PS protection... now it's clear, thanks
Dario
Old 31st January 2012, 02:01 PM   #3637
soongsc's Avatar
We ran through some speakers and amps in listening tests. Very interestingly, the little modded amp presented more detail than another class A amp. Sound stage was pretty much the same, low frequency seemed more correctly damped to me while some preferred a looser beefier low end with small speakers. Sorry for not revealing the exact models because I did not really take care to note what they were. I am happy, but also see some more room for improvement.
Old 31st January 2012, 02:05 PM   #3638
soongsc's Avatar
I am talking about power ground protection in general. X and Y caps have very specific requirements when used for mains power filtering. What I am saying is that it's been confirmed you will have a shock when large currents pass through the ground line of the mains regardless whether you meet the requirements or not.
Old 31st January 2012, 02:27 PM   #3639
....................I appreciate less this sentence.....................
I too would not appreciate that being said to me. But, if I was that irresponsible, then maybe that type of message is what I would need to wake me up.
I stand by what I said. Looks like you have been wakened up.
regards Andrew T.
Old 31st January 2012, 02:48 PM   #3640
Reality first!
Dario
Copyright 1999-2017 diyAudio
