My "audiophile" LM3886 approach - Page 12 - diyAudio
Old 19th July 2005, 06:54 PM   #111
troystg is online now troystg  United States
troystg's Avatar
Ahhhh, I see said the blind man....
Sorry, I thought you meant the opamp. Short sighted on my part.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 19th July 2005, 07:09 PM   #112
Hi all,
How to have said various turned in the thread, this circuit is a lot of nonelementary ( even if with little components ).
The matter of the "thump" is not easily that can be managed because there are 2 Opamp nesting with common NFB, and LM3886 is in configuration to bridge. The mute of LM3886 is unusable, because LM318 would go to clipping for follow the LM3886 STBY.
I have recommended to Russ to follow more possible my layout of the circuit to avoid problems of: oscillations and Ground loop.
The matter of the external Hi-cap doesn't exalt me because sets the "endless" problems described in the Thread " snubber yes or not " but it is a personal choice.
Naturally all am clear of interprets to like them my circuit, but in my layout it is "hidden" different years of technical "analysis"...
ciao
Mauro
Old 19th July 2005, 08:31 PM   #113
Default D-A Question
I see the 14 volt relay for the output. Is there an issue using it to handle the turn on thump?
I do not like the thumps, several amps built have switches on the outputs to allow stabilization then turning on. I use double throw with 15 ohm rsistors on one side for loading and speaker connection on other. A realy is much better, no hassle.
George
Old 19th July 2005, 08:57 PM   #114
BrianDonegan's Avatar
The existing relay switches the speaker output grounds and prevents turnon and turnoff thumps. Does a great job.
Old 19th July 2005, 09:41 PM   #115
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes, Mauro's layout with the relay handles this quite nicely. I will add the same circuit to my layout as well, only for a single channel. I was really planning to all along. I was just not sure if I would do it on the same board or as a seperate board (maybe on the PS). I think now what I will do is a single channel complete with PS on a single board. I will try to emulate Mauro's star ground on the board, I see how he brings seperate ground traces together right between the large caps on his PCB design. I will do the same.
Hopefully I will have something to look at soon.
Really I am just doing this for my own pleasure, so if it is not useful to anyone no harm done.
Cheers!
Less pulp more juice Twisted Pear Audio.
Old 20th July 2005, 01:40 AM   #116
Default Lots of help
Russ,
I for one look forwrd to building an amp with these boards. I have not looked closely at what is on the boards. Guess the relays will either be off board or it will be a mechanical switch to do this.
George
Old 20th July 2005, 02:17 AM   #117
Russ White's Avatar
Hi George,
I still have a lot of work to do on the layout. My intention is to use all of the same techniques Mauro did to the best of my limited ability.
The only major defference will be that my board will be for a single channel monobloc. The reason is because I want to facilitate multi channel amps (such as 5.1).
Cheers!
Russ
Old 20th July 2005, 02:36 AM   #118
Mark Kravchenko
mwmkravchenko's Avatar
Default Buzz a buzz buzzz
Tis a fly looking on. Keep it up!
Mark
Mark
www.kravchenko-audio.com
Old 20th July 2005, 05:11 AM   #119
troystg's Avatar
Originally posted by Russ White
...Really I am just doing this for my own pleasure, so if it is not useful to anyone no harm done.
Cheers!
Russ, your doing a great job, and attraching flies, myself included.
I will make suggestions so you, and Mauro, please feel free to continue slapping my hand as needed.
Mauro- Beautiful concept. I can't wait to hear it.
Troy
Old 20th July 2005, 06:28 PM   #120
What do you think about using CarlosFM's Snubber 1.1 power supply in place of mauro's power supply? I am sold on the advantages of regulated over unregulated, but not sure if it will change the dynamics.
taken from LM338 regulated snubberized PSU for audio amplifiers
Copyright 1999-2017 diyAudio
