Old 6th October 2005, 08:39 PM   #1051
Russ White's Avatar
Send a message via Yahoo to Russ White
A note of caution folks. The mods I made have worked great for me, but I did not design this amp, and I am not sure what long term impact the changes I made have on stability or durability and such, so I would not necessarily recommend everyone go and do what I did. If you do it be very careful. I would also like to say that nobody should feel like they will have a substandard amp if they don't modify it. Nothing could be farther from the truth. Seriously just ask the many who have built from Mauro's, Plovati's, or my PCBs and you will see that the My-REF amp as designed is simply one of the best available chipamps period.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 6th October 2005, 08:52 PM   #1052
well i promised a friend that will build him a all out amp.
2 x 500VA C-core (good old fashion over kill)
2 x dual 18v 40 VA transformers.
finder relay's
caps to be decided
silver hookup wire.
he is supplying all the bits
seeing that the current configuration is the second best i have ever heard i think it justifies the expence.
just for the fun of it . he is 75years old needs something to make him stop complaining about the amps out there.
this should be finished by the end of next week
Old 6th October 2005, 09:03 PM   #1053
troystg is offline troystg  United States
troystg's Avatar
Originally posted by Byrd
i was going to say Russ. 300VA . I know we like overkill here but ehm - what level would be reasonable overkill
I will be bringing mine up to test and burn in with 2 100VA toroids (1 per channel) but plan on replacing that with 2 250VA units later on.
The test units are 25 volt (+1 over spec'ed shouldn't hurt the amp) but will likely go to 24 on the final set.
So the qustion is...
What is the optimal size recommended @ 24 volts? 200, 250, 330? I prefer not to WAY over do it.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 6th October 2005, 09:09 PM   #1054
Nordic is offline Nordic  South Africa
Nordic's Avatar
Ja nee (yes no)
Typical Gauteng move there...
Use a 3 litre Ford to go get a 2L Coke and a 1L Brandy.
You go boet. Proudly South African and all that.
Here it is the night before christmas. Had confirmation today that my specialy wound transformer will be delivered in the morning, lol, also a bit of overkill rated at 6 Amps... and a small 5V 1A winding for leds and small stuff, only cost about R10 extra.
Tomorrow, tomorrow, I love you tomorrow....
Old 6th October 2005, 09:16 PM   #1055
here is some spreading the love. help yourself. but please respect the fact that i do not want commercial versions of this
this is my version
Old 6th October 2005, 09:18 PM   #1056
and the components side
you might find some of my ideas about track layout a bit weird but believe me this baby sings
cheers
Rudi
Old 6th October 2005, 09:21 PM   #1057
Originally posted by Nordic
Ja nee (yes no)
ja boet na so groot zol sal jy 'n groot transformer nodig he om die ore oop te maak
Old 6th October 2005, 09:23 PM   #1058
Nordic's Avatar
Sorry boss, but what is the dimensions for that board?
Also do you have a slikscreen for the components?
.... of 'n klomp kleintjies
Old 6th October 2005, 09:25 PM   #1059
print it out on A4 and you will be OK
175 x 112
cheers
Rudi
Old 6th October 2005, 09:26 PM   #1060
Russ White's Avatar
Anything around 150VA or more per channel is just fine.
Copyright ©1999-2013 diyAudio
