Old 6th October 2005, 09:07 AM   #1021
I´m amazed!
Groundloops's Avatar
Thumbs up My_Ref PCB blowout
Hi Piergiorgio ! Want to get´em ... What is the shipping fee to Germany ? Send me an email.
Gerhard
Old 6th October 2005, 09:37 AM   #1022
Greg Erskine's Avatar
Hi Gerhard,
I was just wondering what "SmellOfPoo" means, is it German?
Greg Erskine
Old 6th October 2005, 10:35 AM   #1023
I´m amazed!
(Should I answer or ... ...) You know it´s not german.
Old 6th October 2005, 12:25 PM   #1024
Default One ohm resistors
Loking over the BOM for the twisted pear mono boards, did not see the 1 ohm resistors listed. Are they in the 1/4 watt group?
George
Old 6th October 2005, 12:27 PM   #1025
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes they are included in the 1/4W bundle
Less pulp more juice Twisted Pear Audio.
Old 6th October 2005, 12:29 PM   #1026
plovati is offline plovati  Italy
Default Re: My_Ref PCB blowout
Gerhard
You should got mail!
Piergiorgio
Old 6th October 2005, 01:50 PM   #1027
sometimes in life you discover something so precious that you want to keep it for yourself. well i wanted to..........
as Ryan suggested. place a 3k3 resistor form the -ve supply pin4 to the output pin 6
viola your stereo becomes a holographic machine. well almost
very worthwhile. try it you might be suprised
cheers
Rudi
Old 6th October 2005, 03:27 PM   #1028
Hey Russ, How is the conversion comming along. once you've done that then try the 3k3 on the 318. this is one tweak that left me cold
cheers
rudi
Old 6th October 2005, 03:31 PM   #1029
Russ White's Avatar
cheers
rudi
Yes I did try it, but I only had enough trafos for one channel. So I will reserve final judgment, but off hand I would not say I was overwhelmed. Still I don't think it was bad.
I actually used a current source to bias the LM318 to class A once. It is indeed quite nice, but it lowers the headroom on the chip a little.
I meant to try it again. This is as good a time as any.
Cheers!
Russ
Old 6th October 2005, 03:46 PM   #1030
I don't blame you if you say you weren't blown away if you used one channel. you obviously need two channels to get the full effect. i think you can even run one trafo for the 18v power supplies. anything over 30va will then do. 9not the best solution but will work) i feel the secret lies in the 18v not 12v
the "class a" trick. well i did not think that it robbed it of any headroom. What it added is so much better than a bit of loss in headroom
cheers
Rudi
Page generated in 0.12260 seconds (59.61% PHP - 40.39% MySQL) with 11 queries
