Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Chip Amps Amplifiers based on integrated circuits |
#3931 |
Reality first!
I'm sorry Andrew, this time you're completely wrong...
It's known that those two resistors in the My_Ref will get very hot, a small heatsink can extend their duration. Last edited by ClaveFremen; 22nd May 2012 at 02:27 PM. |
#3932 |
R.I.P.
I don't know where Clave gets his evidence from but I can see R1 labeled as 47k and connected to PIN8.
Just look at the Post1 schematic and you will see exactly that.
regards Andrew T. |
#3933 | |
Reality first!
Every board ever produced use a different numbering. The image I've attached is from the official My_Ref schematic downloaded from Penasa's site. You can find attached also TP schematic. |
#3934 | ||
R.I.P.
Then try to be helpful and link a post with component numbering to the relevant schematic.
My response Quote:
With a supply voltage of 25V and a 12V Zener the current through R4 can max out at ~13mA equivalent to 169mW, quite low for a 1W resistor. Me, I would use two 2k, 600mW, in parallel.
regards Andrew T. Last edited by AndrewT; 22nd May 2012 at 04:13 PM. |
#3935 | |
Geoff |
#3936 |
OT. HEY - Dueling Gurus both being correct on the same page
![]() ![]() Hoping this leads to a "Beer Summit" - maybe in Paris. ![]()
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 22nd May 2012 at 05:28 PM. |
#3937 |
i just got done installing vcap cutf for c7 and... it sounds like nothing, as if i've taken out c7 altogether.
![]() ![]() Last edited by PreSapian; 23rd May 2012 at 05:28 PM. |
#3938 |
hi would someone post the updated schematics board and power supply PLEASE or point me to the post,
I have just started to mod my chips and would appreciate the info! THANKS ![]() |
#3939 |
after 8 straight hours of listening to music, i just realized that my speaker ports have been plugged up the whole time, doh! (i've been doing this recently after realizing that the chinese plywood i used for the cabinet was still offgasing foul smell from the inside, which had me starting to fabricate a new cabinet last week.)
with the ports clear, the bass just exploded. so much so that it has caused me to write this re-evaluation. the bass increase from mundorf supreme is extreme. almost as noticeable as a half of dario's compensation mod. the cap is there alright, but it's only amplifying the dynamic of the music while remaining utterly transparent. the jump from mundorf is as dramatic as it was from going silmic(no bypass) to blackgate. and since mundorf>>fkp2... it's an obvious heirachy. cutf's been the final piece of the puzzle, the kingmaker, tapping the last bit of magic from myref, and bursting it with bowling alley depth soundstage, vivid harmonics, ultra accurate tonality oh my... i am done. the nirvana is here. 300b, aleph, i need to forget about it all~ so if you gents have a quality .1uf axial caps laying around, please don't hesitate to try them on. i guarantee you i won't have anything to apologize for ![]() Last edited by PreSapian; 23rd May 2012 at 10:02 PM. |
#3940 | |
Reality first!
![]() But you know what I think of phisically big axial caps in C7... The sound you've obtained is better than without C7? If so you're hearing a gorgeous coloration... ![]() |
New To Site? | Need Help? |
